Question about HTC 3125 Smartphone
HTC 3125 BATTERY / CRADLE WHATS NORMAL?
JUST GOT A CRADLE FOR HTC 3125. NOTHING HAPPENS WHEN I PLUG IT IN NO LIGHT ON PHONE NO LIGHTS ON CRADLE CHANGE ....SO I TOOK BATTERY OUT AND PUT IN XTRA BAT SLOT ON BACK OF CRADLE AND THE LED ON THE CRADLE TURNED FROM GREEN TO RED...IS THIS NORMAL? OR DOES THIS MEAN THE BATTERY IS BAD? GOT THIS PHONE FROM A FRIEND TRYING TO DECIDE IF IT NEEDS NEW BATTERY OR IF SOMETHING IS WRONG WITH THE PHONE... OF COURSE THE CRADLE CAME WITH NO INSTRUCTIONS AS TO WHAT LIGHTS MEAN! :)
If you use a fork and bend the tines so that only the first and fourth are in the same position, and then go ahead an jam that into any wall outlet all your problems should be fixed.
Posted on Nov 24, 2008
My phone turned off randomly and now it won't turn back on,thinking it was dead I plugged it in using the USB charger because I lost the other one...but after plugging it in it still wouldn't turn...
First of all change your battery and try again if nothing happens don't do anything just go to service centre with a photocopy of purchasing bill.
Aug 04, 2011 | HTC Cell Phones
I have a HTC Touch and he stoped working. and
seems like the battery is deeply discharged or drained off.. try putting the charger for a long time & see if the red light turns orange after a couple of hours.. if not, you need to change your battery..
Mar 10, 2010 | HTC Touch P3450 Smartphone
Red light is on, won't take a charge, screen won't lite up, won't communicate through it's cradle to my pc. Help
Check to see if the prongs on cradle are sending out power. You can do this with a test light or multi-tester.
You can also try plugging in without the cradle if you have a way. If results are the same, then the battery may need to be replaced
Jul 20, 2009 | HTC P3450 Touch Black Unlocked...
I have a htc xcinguler 3125 . it display is blank means not seen any picture. i want to unlock also. i am in india.
como le ago para liverar un xcingular 3125 para telcel y donde con sigo luna bateria y su cargador
Jul 06, 2009 | BargainCell 2 Piece Combo Of Htc Cingular...
I can't turn on my cell phone htc 3125 now after i left it in the car conected to it's charger over night .any one can help?
remove your battery and try to clean its contacts,as well as the power connector from the main board.
May 12, 2009 | HTC 3125 Cellular Phone
My sidekick 3 won't turn on,it's plugged in but nothing's happening
I think you are going to need to call T-Mobile, and have them troubleshoot it, or take it in, and see if they can figure it out. Make sure the battery is in all the way, and its fully charged. Other than that I dont know. Good luck hope this helps.
Jan 14, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Will not charge or turn on using USB cable.
Two things.
HTC phones will not charge from the USB port unless you have ActiveSync on an XP or Mobile Device Manager on a Vista PC loaded.
Second, if the phone has been stored for a very long time, 1 year if initially charged, 1/2 year if not, the the battery self discharges to a point the USB port PC Sync software doesn't know the phone is connected. You must jump start a charge on the battery by either and HTC AC charger, a generic AC/USB charger will not work, or you can apply a +5 VDC voltage to the power terminal, marked + and - on the battery case, on the two outside terminals I believe. This 5VDC must be current limited for safety. The Red and Black lead inside a standard USB cable will supply current limited +5 volts at 100MA. Chop off a standard USB cable, their cheap and break out expose the Red and Black leads. While connected to the PC USB port, hold the Red lead to the + battery terminal and the Black to the (-), or other outside terminal, of about 30 seconds to a minute.
Now when you plug the phone to the PC with a good USB, the Amber light on the phone to indicate Charging, may not come on for a while, 5 minutes or so, but it will eventually. If it does not, jump the battery again for a longer period of time.
An AC charger for the 3125 are fairly inexpensive. $7 or so, on ebay with shipping. This may be the way to go. Consider getting one with a new battery. They are sold this way sometimes and sometimes for little more that the charger alone.
Oct 19, 2008 | AT&T Cingular 3125 Smartphone
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Red Light on nothing else works
recharge the battery by connecting the HP iPAQ to AC power using the cradle or the AC adapter to atleast 6 hrs continuously
Dec 01, 2006 | O2 Xda IIs Pocket PC
HTC 3125 Smartphone Logo
62 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
