Question about Husqvarna Designer I
Brother PR600 embroidery machine has decided it won't thread any longer, had a wiper error which I cleared but the machine now won't thread the needles?
  • dbooker Aug 23, 2008
    same problem
  • tymish58 Feb 26, 2009
    error message: "Check upper and bobbin thread" for 2,3,4,5 needless, 1&6 workin fine
Just got the pr600 machine. Can't get the upper and lower thread to connect. Keep getting the error message to check upper and lower thread.
Posted on Sep 01, 2008
Hello .
my PR600's touchscreen has stopped working properly.It is now hard to get it to work .
Posted on Aug 10, 2010
Take the two screws out of the bobbin and clean the part with alcohol, there is probably a lot of lint. Also make sure you have the correct needle size. Not all embroidery needles work. Some times the height is a liitle off and will cause this to happen Schmetz universal 130/705H 15X1H 90/14 make sure it is a H
Posted on Sep 07, 2008
Erreur signal de moteur principale
Posted on Jul 15, 2008
4 Suggested Answers
SOURCE: Designer 1: upper thread shredding while embroidering
I too, have the same problem withmy Designer 1. I just bought ISACORD brand polyester embroidery thread to hopefully solve this problem, but I believe it must be a tension problem. I have a "date" with the repair lady on Friday (11/22/08) and if it gets repaired I will re-post what the problem was. Still love the machine WHEN IT SEWS!!
Posted on Nov 16, 2008
SOURCE: Brother pro 600 embrodiery machine
You may have a bent bar inside the machine (big trouble), needle error is easy it is just to wind the big nob at the back of the machine, make sure you are on the correct needle when you move it, on mine it is a little stiff, just do it slowly. The engineer just bent my bar back into shape, that was 1yrs ago. Good luck have fun :-)
Karen (wytchstitch)
Posted on Jan 04, 2009
  • 52 Answers
SOURCE: Wiper error occuring between thread sequence.
wiper error can come from the needle threader not working right, the cutter not working right or the picker not working right, i would recommend taking this to a dealer for service because setting the picker is easy but you have to be in the service program of the machine
Posted on Jul 07, 2009
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
The needle threader on my embroidery machine is no longer working.
There's a possibility of it being related. I would need more information though.
Jan 26, 2014 | Brother SE-270D Computerized Sewing...
I have a pr600 brother embroidery machine,it trims the thread too short
Make sure that when your machine stops and cuts that your needle is in the upper most position. Other than that you may need an adjustment from a pro repairman.
Dec 04, 2012 | Sewing Machines
Cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Chris
Jun 05, 2010 | Brother CE5000 Computerized Sewing Machine
Brother Embroidery machine thread keeps breaking
the needle thread tension is wrong
bunching up under the material indicates that it is too loose
Nov 17, 2017 | Sewing Machines
Brother 2001 sewing and embroidery machine.
The fact that your machine is turning hard says you still have some thread inside the machine that is binding up and activating the safety device. It must turn easily before it will work properly again.
Sometimes the machine must be disassembled to remove these threads.
sewman7
Jun 16, 2008 | Brother Sewing Machines
Problem After Oiling
More than likely the machine is okay but when you do the embroidery the presser foot is not all the way down and it has no tension. The other possibility is that the thread is not in the take up lever all the way or is slipping out.
sewman7
May 19, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
1,181 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
