Question about ASUS Maximus Formula Motherboard - 45nm Support, Intel X38, Socket 775, ATX, Audio, CrossFire Ready,
Eax300le-a334c rev1.01 no signal
I have a eax300le pci-e put in in and it runs for through windows start up but then says no signal. Is there a fix for this thanks kevin
  • Anonymous Jun 26, 2008
    Had the same problem. The GPU on the card overheated which caused the problem. Replaced the card and everything was fine.
  • halfordlee Jan 02, 2009
    I have a eax300le pci-e put in in and it runs for through windows start up but then says no signal. Is there a fix for this thanks MICHAEL
Try downloading the ATI Radeon x300 series driver if you haven't done so already
Posted on Oct 18, 2008
Why will HP a6700f onboard VGA connector will not provide a signal ?
have you tried when in the vga card to go to control panel/display and look at change display settings and connect to a projector?
Mar 07, 2017 | HP Computers & Internet
How to repair system32/drivers/pci.sys w/o any CD
  1. Shut down your computer, and then remove all the Peripheral Component Interconnect (PCI) devices.Restart your computer.If Windows starts successfully, shut down your computer, and then reinstall the PCI devices one at a time. Start Windows after the installation of each device. When you install a device that causes the issue that is described in the "Symptoms" section, remove that device, and then continue to install the other PCI devices.
  2. If Windows does not start successfully, remove one or more of the memory modules(RAM) that are installed in your computer. Leave sufficient RAM for your computer to start and run Windows XP.
Aug 29, 2010 | Intel Computers & Internet
The problem Started with the pc occasionally freezing. Then it the screen would fill with colored lines. After restarting sometimes it would work for a day or 2 or most times about 5 min. before going...
Hi jonmike
First,holding the power button in won't do anything to the Bios.Holding it in for 5 secs. while the machine is still operating under Windows will shut off the machine though.
Put your PCI video card in any of the slots, then go into your Bios.
Different Bios writers use different places and nomenclature,but generally there's an entry in integrated peripherals or the like that sets whether the primary video is "on-board" or PCI/AGP. You need to make sure you change your settings from on-board to the PCI for primary,if that's not already done.
Let me know,and if this helps please rate my post.
Thanks
Bob
Aug 12, 2010 | HP Compaq Presario SR2023WM PC Desktop
Need the driver for the video card (asus-eax300le-a334c rev 1.01)
What O/S are you using? (Operating System. Windows XP is one example of an O/S)
This is Asus Support, and the Downloads page,
http://support.asus.com/download/download.aspx?SLanguage=en-us
On this page go to the right to the heading - General Download
Under this heading you will see three long boxes.
The first box states - Select Product
Go to the far Right of the box, left-click on the blue down arrow.
In the drop down list left-click on - Graphic Card
Go down to the next box, Select Series.
Left-click on the blue down arrow to the far right of the box.
In the drop down list left-click on ATi Series.
Go down to the next box, Select Models, and left-click on it's blue down arrow.
Scroll the list down to - EAX300 Series, and left-click on it.
Now left-click on Search, in the green box.
The page will 'gray out', and there will be a small window that pops up.
Please select your operating system.
Go down to the box with - Select OS, in it.
Left-click on the blue down arrow to the right of the box.
In the drop down list left-click on the O/S you are using.
I'm going to choose WinXP for an example. (Windows XP. Doesn't matter if it's the Home Edition, or the Pro Edition)
Left-click on Search.
Left-click on the + sign to the left of VGA.
There are 5 files shown.
My advice would be to choose the latest one.
This is the file on top.
Version 8.592
Go to the right of the heading - Download from
Left-click on - Global (DLM)
In the small box that pops up, type the letter/numbers that you see, into the box.
NOTE*
If you see letters, be Sure to type capital letters!
Left-click on Submit.
Your driver download will begin.
Jul 07, 2010 | ASUS Computers & Internet
E-machine t6212 won't boot. I actually have two e-machines that are not sending a signal to the monitor. One is a t6212. It is booting up because I can shut it down using the windows key + up arrow +...
If you get only one BEEP at boot then the computer is working..
Do you have a 2nd monitor to test with?
if it BEEPS more then once...
pull out your mem chips and test,,
If itt works them one of the mem chips are bad if not..
pull out all pci cards and test.. if it works its a bad card...
if not unplug all HD and CD roms and test.......
If not fixed yet it maybe a onboard video problem...
But IF you put a video card in b4 the problem started then your bios may have auto set it sellf to PCI/AGP mode.
Check bios setings,, look for onbord setings for the video
Feb 21, 2010 | E-Machines T6212 PC Desktop
Monitor says check signal checked the monitor on another computer works fine changed mother board same problem only things still left memory and hd and dvd rom drive.
The problem is something you have recently changed( i.e. new memory, processor, video card) does not agree with your board. Good place to start is to remove ALL memory sticks and pci adapters and try it then. Try one component at atime and start putting them back in. Restart and run every time you put something new in thew board. Hope this helps
Oct 02, 2009 | Microsoft Windows Vista Home Premium with...
Can't identify graphics card
download, install and run : everest home edition
it is free and will tell you lots about what is under the case
Mar 08, 2009 | HP RADEON X300 SE, (128 MB) PCI Express...
PCI Device Conflict
u can try to change in BIOS, the settings that manages PCI IRQ's. If it is on manual then put it on auto mode. If on auto mode than manualy change the allocations of irq for the pci slot no. 5 ....
Jan 20, 2008 | EPoX EP-9NPA7I (0819366003415) Motherboard
Open Questions:
Supreme FX II Won't work Ok, let's start from the top- Bought an ASUS Maximus II Formula mobo off of NewEgg. Open box version, since I'm an idiot. That was my first mistake obviously. So, naturally, it doesn't come with ANY of the parts it's supposed to- LCD Poster, Supreme X-FI II, nothing. yay. Anyways, I finally tracked down a sound card (the X-Fi that was actually supposed to come with the motherboard). Installed it- nothing. Didn't show up in device manager, nothing at all. So, I swapped PCI-E slots, and still nothing. (PCI-E x1). So here I am, mad that I bought a sound card from some guy that didn't work. Well, I happened to come across another one, same exact card. So I tried it, all happy and everything, as I KNEW this one worked. NOTHING. Updated the BIOS- nothing. Changed a few settings, such as turning off PnP OS, tried a couple other small things- nothing.,... I'm beginning to think that the mobo has bad PCI-E x1 slots- all other slots work though. Is there any other way they could possibly be disabled by something? Please give some ideas to try, including the simple ones- I'd like to try to solve, as the mobo did cost a good bit. System Specs: Vista Ultimate, XP Pro, 7 RC (tri-boot) (card does not show up in ANY OS) - All have updates. 4Gb DDR2 1066 (OCZ) Intel 3.0 Ghz E8400 CPU Nvidia 9500 GT 1Tb total drive space. Currently having to use a POS Soundblaster Audigy (original) To be honest, I could care less about the X-FI. I just want my FP audio to work. But the mobo has no headers- the FPAUD header is on the sound card. But, the X-FI would be a nice upgrade.... Please help- I can't afford a new mobo right now. Like I said, even give me simple solutions- sometimes we just skip the easy stuff without realizing it lol And you don't have to use laymans terms with me- I repair PC's for a living lol. Update- Tried placing sound card in x16 slot- lit up (which it did before), but still not showing up in device manager. Tried placing it in same slot my video card was in (since I know that slot works) - nothing. So, now we know its not a faulty slot. Tried disabling PCIE Spread Spectrum, CPU Spread Spectrum. Nothing. Tried both cards in all 4 PCI E slots - nothing still... Also removed Audigy while doing this. So- we know the card works, as I saw it work earlier on a different PC. We know the slots on the mobo are fine. I've tried everything in the BIOS I could think of. When I try to install the drivers- says no supported device found. Update- Took both cards up to work. Plugged into one of our shop machines- still nothing. HOWEVER. The second card that I had come across, was out of a customers machine- and of course, it works in his with no problem. So I know the card is good. Yet, it won't install on ANY other machine.
May 08, 2009 | ASUS Maximus Formula Motherboard - 45nm...
ASUS Maximus Formula Motherboard - 45nm Support, Intel X38, Socket 775, ATX, Audio, CrossFire Ready, Logo
1,612 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
