Question about Hoover U8147-900 WindTunnel V2 Bagless Upright Cyclonic Vacuum
Replacing a hoover windtunnel vacuum belt U8147-900
I am up on a ranch 100 miles from repair help and need to replace the belt and brush roller. I can replace my Sharp in 30 seconds, but i really need some help with this one. Lots of screws and no movement of parts. Can you help me?
  • 1,673 Answers
This has no belts, there are 4 small brush rolls, if the ends are bad and not turning then you will need to replace them. The newer ones have metal instead of plastic so are better. Should be able to buy the brush rolls at a local shop or from
Posted on Jun 17, 2008
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
How do you replace the beater bar belt on the hoover u 6626-900
It is not a "Beater Bar". Hoovers have brush rollers and are easy to replace. Turn the machine over and remove the 4 screws which hold the cover on, over the brush. Remove the brush roller. Slide the new roller through the small belt (self propelled models) and secure into slots (note: slots are different, match roller sides to correct slot.
Sep 20, 2011 | Hoover U6630-900 WindTunnel Bagless...
Brush roller not spinning properly
Yes there is a belt and yes it is easy to replace it. There are a couple of screws that hold the cover on and then you can just lift out the brush, get the new belt around the motor shaft and then around the brush. The new belt will need to be stretched tight but that is a good thing....
new belts can be purchased at many grocery stores or vacuum repair shops...
Apr 29, 2010 | Hoover Commercial Windtunnel C1705-900...
Describe how to replace belt on hoover windtunnel bagless
If you turn the vacuum so the bottom is facing up you will see the base plate that covers the roller brush. There will be four screws (usually phillips head), remove the screws and the base plate will lift off. You now have access to the roller brush and belt. Lift the roller brush up and remove the old belt. Place one end of the new belt over the motor shaft and the other end over the roller brush and put the roller brush back in place. Now simply replace the base plate and you're done! This models requires Hoover belt # 38528033 (single) or Hoover belt #40201160 (2 pack). You can get this belt at
Here's the pages:
Oct 15, 2009 | Hoover U5750-900 WindTunnel Bagless...
Brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Mar 21, 2009 | Vacuums
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U8147-900 WindTunnel V2 Bagless Upright Cyclonic Vacuum Logo
332 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
