Question about HP Compaq Presario V2000 Notebook
Compaq Laptop Overheating
This is the second time within 4 years I had to replace the CPU fan. The first time was under warranty, this time I attempted to replace when I disconnected the wire the connection pulled away from the computer, is this something the Geek Squad could repair?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 114 Answers
Sounds like you need another motherboard or prepare to get out the solder iron and correct yourself.
geek squad will not solder back on connectors, what you should do is take it to the local pc repair place and they might solder it back on. call around and ask if they can solder a component back on, it might take a couple calls to find one that will.
Posted on Jun 11, 2008
Compaq laptop powers up for thirty seconds then shuts off
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 13, 2012 | Compaq Computers & Internet
Sony Vaio has started shutting down unexpectedly. Restart in safe mode and run event log with no results returned. Shutdown and restart. Starts normally but then shuts down within 2 min. Repeat process,...
Your pc CPU FAN is not working, you need open it and clean fan,, and under fan, on CPU there is termo cream, don't frgot about it, you need clean it and put new termocream. it is nessasary for cool CPU, that Cpu can not be warm.
Jun 11, 2011 | Sony VAIO Laptop
Hp 6735s turnin of itself and is overheating
To avoid laptop overheating, follow the information from this link.
Oct 26, 2010 | HP Compaq 6735s Notebook
Turn on laptop. within minutes fan is running full bore and bottom is very hot
is this a new laptop? if not it may be that the fan needs a clean and new thermal compound needs to put on the cpu. if it within warranty i would contact compaq. You can do it yourself if you know what your doing but if you don@t then please don't try it as involves know how and if you mess it up you could have a dead laptop @ the end.
www.pctechguyonline.com
Feb 02, 2010 | Compaq Presario F730US Notebook
C300 Switches off
The Compaq C300 laptop most likely is overheating and shutting down (ie thermal overload) and will not bootup again until it has cooled down. If this is not fixed eventually the CPU will fail.
The overheating is caused by a faulty fan and/or dust clogging the heatsink and fan assembly.
Check the fan to see if it spins freely (replace the fan if it is faulty) and use a stiff brusk to loosen the dust from the fan and heatsink and vacuum the dust from the fan and heatsink.
If you remove the fan assembly from the CPU then apply fresh thermal paste to the heatsink pad before placing it over the CPU.
The laptop should be placed on a flat surface so the vents are not obstructed. You can also place the laptop on a fan assisted base to provide additional cooling.
Sep 20, 2009 | Compaq Creative Sound Blaster PCI 128...
My Compaq v6000 notebook doesnt power on all lights just go on for a second then nothing... both with battery and adapter, the charge lights go on that's all when its plugged in. no sounds at all...it was...
same thing happened to my good old Dell 600 laptop ... in my case, I just remembered that this is many times a safety feature which is just doing its job, kicking in to protect your CPU. That is, it sometimes happens that the little fan (which is little but does a big job, i.e., blows air over the CPU right next to it and keeps the CPU from overheating) just flat wore out and is not turning. Very easy to check -- just turn your laptop on its side and look at the fan while you push the button to turn the laptop on. Odds are you will NOT see the fan turning, so you need to go onto Ebay or some parts store near you and buy yourself a replacment fan for $15.00 and then download the manual or hunt in a forum like this one for the steps to replace the fan. Or take your computer to a shop where they will charge you $65.00 for the fan and $45.00 to install it. Your choice. Hope this helps.
Sep 19, 2009 | Compaq Presario Notebook
Laptop Fan Sounds real Loud.
I would either call HP or if you got th extended warranty and go back to the store and have the take care of the repairs so you don't void the warranty. You can tell them the mousepad is worn out and it won't move the mouse properly and also explain about the overheating problem, both should be covered under warranty.
Feb 17, 2009 | Compaq Presario C700T Notebook
Noisy fans laptop overheating?
Try using Compressed Air in a can by the vents. I would not recommend taking apart the laptop.
Dec 22, 2008 | Computers & Internet
The HP Presario A900 shuts down within 5 minutes of start up
If your laptop is overheating, it means that the Processor fan is not working. You can damage it further if you keep trying to us it. Although I must say, this is the first time I've heard of using frozen veggies to cool it down. I have a client that bought a portable Air conditioner to cool his laptop. I fixed it by replacing the fan.
The fact that the unit works while being cooled externally points directly to the fan.
Is the unit out of warranty?
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 26, 2008 | Computers & Internet
M2000 laptop
If you are trying to say
"I"ve had to replace my battery 3 times in two years, the battery compartment gets very very hot, and the techs couldn't figure out why"
I might be able to help. It's always helpful if you use whole and complete sentences and tell us, with all the specifics possible, what the problem might be.
I TAKE NO RESPONSABILITY IF YOU FRY YOUR COMPUTER OR VOID YOUR WARRANTY. PROCEED WITH FIXES AT YOUR OWN RISK.
You might try a hardware solution to cool your computer, one that won't entail opening it, that will work while your getting or act together to actually find and affect a fix.
http://www.become.com/shop?q=notebook+fan
Is anyone aware that HP had a battery recall? Apparently the batteries were over-heating and causing problems.
http://www.consumeractiongroup.co.uk/forum/pcworld/19432-overheating-compaq-laptop.html
Legal action, Re: over-heating batteries, seems to be in the works here:
http://www.lawyersandsettlements.com/case/hp_notebook_batteries.html
You aren't the only person with this problem:
THis is a piece of software you might download, it's called "SpeedFan"
http://www.download.com/SpeedFan/3000-2094_4-10540297.html?tag=lst-3-2
Maybe I can answer your question or give you ideas of other problems that may be causing your problem.
The Compaq 2000 series are known as "bottom breathers" because that's where the fan is. Heat is the enemy of any laptop, of computers, period. For a bottom breather this poses an even greater problem.
I noticed a small componant in a friend's shop. The componant was a small bank of 3 fans, in a laptop size, 1/4 inch plate. The fans blow up underneath the the laptop, to reduce radient heat from the resistance of the current moving through the computer, and to help cool the electrical parts of the computer. The fan under the laptop gets more, and cooler air.
I bought it because the mouse padand the working surface my M2000 get to be about 105 degrees - right at the edge of comfort to the touch.
Since I started using the external fans, I would say that the temperature has come down 10 degrees on the surface of the working surface of the computer and the mousepad.
That might solve your heat problem, which may be causing your battery problem.
I've also been looking into over-heating problems with Compaq models. It seems that several Compaq computer models have over heating problems. These are some fixes that people have tried, with more or less success. Some are very low tech.
=> Add a desk fan to increase over all ambient air circulation.
=> Clean the vent on your computer
=> Suspend laptop over desktop with books on each end, so that there is an air-pace under computer.
=> Build some sort of wood or plastic lift to keep your laptop suspended over your desk and allow airspace and, if you are electronically inclined you can build a fan into the platform.
(Actually, if you build it especially for your computer, you can add seveal fans and vent the unit directly to the laptop fan. Have it plug it into the wall socket and use it at home.
(I bought one from the computer store, premade, 3 fan, but it's generic and doesn't ram air directly into the fan. It just creates dditional airflow to evaporate the heat. It plugs into the USB port on the computer.)
Excess heating problems
1) The heat-sink isn't seated properly, or is loose.
Reseat heatsink, tighten, adding thermal grease and thermal pad(s)
2) Fan is burned out, burning out, or is just not up to par.
Add, or replace existing fan(s) and/or thermal pads on the CPU.
3 ) Use thermal grease between the pad and the CPU and/or fill in gaps between thermal pad,
4) In some Compaqs if the RAM memory chip(s) go bad,
Test by using RAM chips that can be verified as "good" and if need be, install new RAM chips.
4) Sometimes the RAM socket goes bad.
Test them with RAM that can be verified as "Good" and see if your bios and computer notice. Replacing the docking port for RAM might be a job for the shop.
This is a good fix, and I'll probably employ it soon:
tyler said on July 1, 2007 06:58 PM:
My v2000 has been doing the same exact thing. the problem is actually overheating. For some odd reason HP decides to put a thin piece of aluminum foil that seperates the processor from the thermal paste. All I did was remove my HD and battery. then unscrewed every screw and removed the bottom plate. I then took the screws out of the coolant system and removed it to reveal the processorand GPU. at the bottom of the coolant system was a piece of aluminum which I removed. Cleaned out any lint or dust build-up near the CPU/GPU, Then took off the thermal paste from the bottom of the cooling system and spread it evenly directly on the processor heat concentrator. I Put the cooling system back on correctly (must be as tight as you can possibly make it) and screwed the bottom plate back on/ put HD and battery in. Sounds complicated but it really isnt. Also, my CPU temperature is at an all time low of 35-37 degrees (C) browsing the internet. Im not sure if this Voids warranty, but this fix has done wonders and I dont get anymore random shutdowns. I hope this helps some people.
OR this could be the problem if you've recently changed your operating system
Re: Overheating issues with Compaq Presario 2765
Hmm... you recently installed WinXP... did you install the AMD processor driver afterwards? If not, CPU power management isn't enabled. Your notebook still shouldn't crash but if there is a heat problem, enabling power management will help. You'll also need to set your Power Scheme to Portable/Laptop.
1.69GHz (we'll call it 1.7GHz) isn't right, that generation of Turions is 1.6GHz, 1.8GHz, etc. in 200Mhz increments. See what CPU-Z says your speed is, before and after you install the processor driver if that driver isn't installed already. (http://www.cpuid.com/cpuz.php)
This is a great URL for cooling issues.
Guide to Cooling Down Your Notebook Computer
http://www.fixya.com/PostAnswer.aspx?thid=218333&prdid=357146
AND if you're running XP, read THIS URL.
http://www.motherboardpoint.com/t36858-compaq-presario-700-laptop-overheating-problem-solved.html
I took this next comment from:
http://www.techsupportforum.com/hardware-support/laptop-support/111525-fan-not-running-overheating.html
Check when you first power the computer on whether the fan spins, even if only for a second then cuts out once the Windows logo shows on screen. If so there could be a problem with the windows acpi system. I found that by uninstalling the following :
ACPI Thermal Zone
Microsoft ACPI-Compliant Embedded Controller
Microsoft ACPI-Compliant System
from system devices in device manager then restarting the computer I was able to get the fan operating within windows again. BEWARE before performing this as you will need to reinstall drivers for your modem and video controller after performing this which you probably wont have as compaq doesnt ship the drivers with the notebook and you wont be able to get to the net without modem drivers if you use dial-up.
God I love Google.
Oct 11, 2007 | Compaq Presario M2000 Notebook
HP Compaq Presario V2000 Notebook Logo
63 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
