Question about Kenmore 43042 Front Load Washer
Water leak on occasion front load washer purchased around 2002/03
My washer leaks underneath, front right side. SOmetimes I can do 4 loads and the fifth load it will leak. OTher times I can put just 5 t-shirts in and it leaks. I use HE detergent as my mom had similar problem with her kenmore and was told it had too many suds which caused problem. THere seems to be no rhyme or reason to when it happens, but I have noticed it is more frequently. Any suggestions, especially since my mom experiences it with hers from time to time.
You need to remove the kick panel (under the front door). There are two screws at the very bottom of the kick panel, one in each corner.
This will give you visibility to see where the leak is coming from.
On the right hand side is the drain pump. The black hose goes from the pump,out the rear and into your drain pipe. It is secured by a clamp and is one possible source of leak.
If that connection is dry, look underneath the tub where the two parts, front and back of drum, come together. there is an o ring sealing the two sections and this is another source of water leak. (major problem is this is leaking)
Failing this you will just have to trace the source of the leak. You may have to take off the top of the washer to check the water inlet hoses which run on the top of the machine but would still show as a leak under the machine. Good luck.
Posted on Jun 30, 2008
Electrolux front load washer leaks from soap drawer
This is a common problem with front loaders. Probably poor design.
Jun 23, 2017 | Electrolux AWF 1435 Front Load Washer
The washer leaked tons of water out from the front. what would cause the washer to leak out of the front?
hello there may be holes in the door seal or seal around the front. also check the pump underneath hope it helps
regards
shaun
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks out front center of door during the
Check the door gasket for any damage. A rip or a tear could be the cause of the leak.
Jul 20, 2010 | GE WSXH208A Front Load Washer
Leaking whirlpool washer
Probably the pump seal - you need to replace the pump, which is located at the front.
Apr 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
I transported my frigidaire front load washer.water leaks.
Check your pipes /drain and sump hose sounds lie something has came off in transit
Apr 08, 2010 | Frigidaire ATF6000ES Front Load Washer
The front load washer is less than 4 years old and has been leaking from the front door since we purchased it. Rust has appeared in front of the door and now has rust on the side due to leaks. I am afraid...
And so you should be. Anyone who continues to use an appliance around uncontained water is inviting electrocution..
I cant begin to fathom out Why??????????
Oct 20, 2009 | Kenmore 43042 Front Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Washer tub slowly fills with water
Is your problem a SLOW FILL problem, or a problem with WATER DRIPPING FROM THE RUBBER DOOR SEAL - or BOTH? If you have a slow fill problem, this is generally caused by a bad fill valve, which can be attributed to hard water deposits or well water mineral deposits. Sometimes the fill valve can be removed, cleaned and reinstalled, but most of the time a new fill valve is required. If you are experiencing water leaking from the rubber door seal (bellow), it may be time to replace it. Sometimes the seal can develop a wrinkle or crease where it meets the glass, which can cause leaks. Water dripping from the door when you open after washing a load is normal. Water dripping during a load is NOT. The bellow may also have started to rip or tear inside the door which may not be noticeable until you pull the folds of the bellow back and look underneath it. I hope this helps.
Jan 17, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 43042 Front Load Washer Logo
166 people viewed this question
Sal De
fordexpert
Robert Rankin
