Timex NatureMP3 Clock Radio T617S Logo
Posted on Jun 11, 2008
How to set the main clock
Has two alarms with sounds and cd but how to set the main clock time
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Feb 22, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
9080
Points
40
Go to timexaudio.com, select SUPPORT, then select PRODUCT MANUALS.
I can't find how to change the time for the alarm system for a Alphaline 150i digital radio alarm clock
PDF]Instruction Booklet - Sound Therapy and Relaxation Clock ...
www.conair.com/instruction.../07ps111_su7_ib.pdf
Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
Muse - Alarm clock radio
www.muse-europe.com/en/products/alarm-clock-radio
Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
[PDF]FM/AM Clock Radio - Sony
Jan 10, 2016 • Watches
I need a manual on how to set the time and alarms on fm/am cd clock radio model # rp 5600a
To set the time, press Set (furthest left button in the line including the Snooze) repeatedly until the clock icon shows on the display. Then press the FWD or REV buttons (on either side of the Snooze button) until you reach the current time. Press and hold to advance the time more rapidly. Press Set to save the time.
To set the alarm, press Set until Wake 1 or Wake 2 is shown on the display. Then follow the same directions as changing the time. Press WK1 or WK2 on the front of the clock to select the type of alarm.
The manual for the RCA RP5600 is available on the product page: http://www.rcaaudiovideo.com/audio/clockradios/?sku=RP5600 . See the Support/Manuals tab. The direct link to the manual is http://audiovox2.info/docs/common/RP5600/RP5600_OM.pdf .
I hope this helps.
1helpful
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
My alarm is set...but it doesnt go off.
There are 2 common mistakes with radio alarm clocks. 1) You have AM/PM backwards either on the actual time or alarm time 2) The volume is mistakenly set all the way down
11helpful
Hi i have a rca Clock Radio RP5435C i need to know how to set it.
Move the switch on the top back to either the clock symbol to set time or alarm 1 or 2 depending on which one you wish to set. On either side of the snooze button is a fwd and rev button. Push fwd to advance the time or rev to go back. If setting the alarm it will automatically turn the alarm on when you set it. To turn alarm on or off manually, push the button for the alarm you choose on the top rear right side.
13helpful
How do you set the time and alarm on the RP5600A
Setting Clock
1. Press SET repeatedly until a clock icon
2. Press REV or FWD to set the clock
time. The time decrements or
increments will follow by a faster rate
when you press and hold the buttons.
AM or PM icon will also show beside
the time.
3. Press SET when finished.
Setting Wake Time
This unit allows two wake times to be set.
1. Press SET repeatedly on the top of the
unit until you see WAKE 1 or WAKE 2
flashes on the display.
2. Press REV or FWD to set the respective
wake time. The time decrements or
3. Press SET repeatedly until you see no
WAKE 1, WAKE 2 or icon the
display.
Selecting Wake Source
You may be woken up by radio, CD or alarm.
1. If your desired wake source is radio or
CD:
• Wake by radio - select an AM or FM
station (see directions on “Radio”).
• Wake by CD - insert a CD in the CD
compartment. If you want to be
woken up by a specific track on the
CD, press and hold wake up - cd
track
on the top of the unit and at the
same time press REV or FWD to select
a desired track.
2. Set a wake time (see above direction).
3. Press WK-1 or WK-2 repeatedly at the
front of the unit to select a waking
mode. Corresponding icon lights on
the front of the unit.
- Wake 1 by alarm
- Wake 1 by radio
- Wake 1 by CD
In case of Wake 2, “2” shows at the
centre of the icons.
ALARM CLOCK SETTING
I've manage to set it... press time/awake and the 1 flashes... use arrows to set the time... then press time/awake again for alarm 2.
But how do you know when it is actually set?? it did not go off this morning and i was late for work!
4helpful
Instructions; TIMEX Alarm Clock Radio w/CD Player & Nature Sounds
9helpful
Setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
2helpful
2answers
Changing between the buzz and cd setting for alarm clock
From the manual (miraculously, I still have it)...
To switch the alarm sound between buzzer, church bells, radio or CD, press MODE one time, and then press REPORT.
If CD is selected, press TUNING up (>>+) or down (-<<) to select desired wake-up track.
When alarm sounds, press ALM ON/OFF to silence alarm and reset it for the next day.
SNOOZE-BOOST
To postpone the alarm once it sounds, press SNOOZE/LIGHT. Each press of this button will add 10 minutes to the postponement time. (Pressing three times will give you a 30-minute delay).
Top Timex Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
