Question about Internet Computers & Internet
Wireless Internet For Laptops
Is it possible to have a wireless usb internet connection for laptops. Being able to connect to the internet no matter where you are, within reason of course. Or do you have to have a internet hub or seperate modem in your home for the wireless internet to work.
Say for example I want to, for some reason use my laptop and internet in a park someplace. What do I need to make this happen and what distance restrictions if any are there.
Thanks!
    Scholar:
  • 50 Answers
KDunstan -
It is possible to plug a USB wireless adapter into your laptop and connect almost anywhere, however there are limitations; You won't be connecting to your own ISP unless you are within range of your wireless router, and you need to be within range of ANY wireless router to get wireless internet access at all.
What makes wireless connections convenient in a laptop is the fact that many businesses - coffee shops, bars, hotels, even McDonalds - offer free wireless access, or very low subscription rates.
I'd also like to point out that you may not need to purchase a wireless USB adapter; If your laptop was built anytime between 2005 and today, then it most likely has a wireless card already built in; refer to the laptop's owner's manual, or the manufacturer's web site, for more info.
*Note* If you find that a USB device, or built in wireless adapter, don't have as much range as you'ld like, most computer stores sell seperate antennas for boosting range.
Hope this helps!
-thinstatic
Posted on Jun 11, 2008
  • 114 Answers
Some access points have codes, your laptop has to be able to pick up a access point. But in 2012, There will be a thing called Wi-max which means Wireless internet will be all over the world no matter where you are. So you can go on the internet wherever you are as long as you can connect to someones access point.
My lap top isnt set up for wireless connection to internet
Connecting laptop/computer to wireless router
If you have a wireless router and it is connected to the DSLor cable modem and Internet then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jun 16, 2012 | Samsung Computers & Internet
Tip
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet connection..here it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "192.168.000.001" and "Subnet mask" as "255.255.255.0"
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"192.168.000.002", Subnet mask "255.255.255.0", Default gateway-"192.168.0.001" and Preferred DNS server: "192.168.000.001".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex- 192.168.0.3, 192.168.0.4 & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
Can eee asus 1008HA laptops use a prepaid 'stick' for internet connection?
The USB wireless stick uses the cell phone network for wireless Internet connection provided it is within that ISP cell phone coverage area.
I doubt you can use a 2nd hand USB wireless stick unless the service is transferred to you. It is best you organise your own Internet connection with a ISP of your choice.
Laptop battery are removable and can be replaced when they are worn out, BUT the BIOS battery is inside the laptop and this can be changes but requires getting access to the insides of the laptop.
Apr 11, 2012 | Computers & Internet
Dear Sir, There is no provision of fixing my laptop to a wireless router.Can anybody advise how to convert this laptop to enable getting wireless connection of internet?
There's a lot of available wifi adapters out there that you can just plug into your laptop's usb port. You can try looking them up online or in computer shops.
Jul 29, 2011 | Computers & Internet
I would like to know when it say laptop with built in wireless. Does that mine i already got internet service on it. Or i have to buy USB modem.
Hello Blac,
All the laptops available in market have built in wireless 802.11 b/g/n or 802.11 b/g/n Bluetooth® wireless networking. It means that you can access the internet via Wi-Fi or through Wi-Fi hotspots. In wireless connectivity you do not require the wired connection to access the internet. In home you can connect the laptop via wireless connection using the home networking router available in market. The advantage of wireless connection is that you can use the internet in your home anywhere with in 100 meters of range with proper wireless signals. You will require to get the internet connection from the ISP(Internet Service Provider).
Please visit the link provided below for Home Networking Wireless Router :
http://www.netgear.com/home/products/wirelessrouters/
Jun 29, 2011 | Computers & Internet
Do i need a wireless card for my acaer aspire ax3300 desktop
The Acer Aspire AX3300 does not come with a wireless card. Here is a link to a wireless card that plugs into a USB port. http://www.newegg.com/Product/Product.aspx?Item=N82E16833704045
Mar 06, 2011 | Computers & Internet
I want to connect with the internet but they say there is no access point doesn't matter where i am can you explain it how to do it the easy way
To connect to the Internet via a wireless router both the wireless router and your wireless card in you computer needs to be configured.
Your wireless router, the router needs the wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router.
Feb 26, 2011 | Computers & Internet
How can I connect 2 laptops on internet wireless using 1 modem
Hello.
The best way is to get a network hub. that way you can connect the modem to one port, and the laptops to thier own port. Now if you have wireless on your laptops you would be better off with a wireless hub. This will do the same thing only wirelessly. You can pick up 102.11B wireless routers very cheap on ebay. This is older technology, but it will still give you about 1.8MBs wirelessly. You could go buy the latest and greatest, but remember, no matter how fast your router is, you will only get whatever your internet connection will give you.
Apr 15, 2009 | Computers & Internet
Wireless internet connection
Try to update the wireless driver of your Laptop.
Mar 09, 2009 | Compaq Presario CQ60-220US PC Laptop
Wireless MODEM for Internet connection compatibility with Laptop
Compaq/HP laptops that have a builtin wireless adapter have a wireless transmitter symbol near the bottom edge of the LCD screen.
If you don't have a wireless adapter you need either a PCMCIA or a USB wireless adapter. My choice would be a PCMCIA type because it frees up a USB port for other devices.
Jan 24, 2009 | Compaq Presario Notebook
Computers & Internet Logo
252 people viewed this question
Tejodhar Atreya...
Tejodhar Atreya...
vojvodabudva
