Question about ASUS P4S8X-MX Motherboard
Setting up a Computer to install Windows XP Professional.
Motherboard ASUS P4S8x-MX
DVD Rom.
Sony CD Rom
Western Digital Hard Disk.
ZIP Drive.
I need help on how you conect this drivers to the motherboard. Which are the masters and which are the slaves to have the best performance.. My E-mail address is : cruz 1891@bellsouth.net. Thank you. Pedro Cruz.
    Scholar:
  • 50 Answers
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Posted on Jun 11, 2008
New ASUS A8V-MX motherboard will not boot to CD or HD with XP
The first thing is to make sure that your CD/DVD drive has the windows disk in it. Also check drive C which is where the windows will be installed. It may require that it is hard formated. Hard formatted means "format x /u" [format-space-drive to be formatted-space-right slash-u]. This will place the drive for "windows xp sp2", all of it, to one pass of zeroes. So, once we have a clean drive C and the installation disc is inserted into the CD/DVD drive, you may proceed to install. You will need to find "install" or "setup" and start it on he "RUN" mode. Any questions or help get back to me. CONSTANTIN (arzconst)
Jun 03, 2009 | ASUS K8V-MX Motherboard
Not installing windows xp with asus k8v-mx motherboard
Sounds stupid but I have seen it happen. Make sure the cd in the first in the boot sequence in the set up. If that dont work make your c drive first. Give it a shot, may work..I love asus
Sep 23, 2008 | ASUS K8V-MX Motherboard
Asus p4s8x-mx support CD
If you want a copy of the CDs contact Asus by clicking here and ask if they can sell you a replacement cd for your model.
Instead of getting a replacement CD you can download and run the drivers from Asus download page here:
DRIVERS for Asus P4S8X-MX Motherboard
Sep 05, 2008 | ASUS P4S8X-MX Motherboard
Problem loading windows xp
try disabling legasy USB devices in bios
Jul 09, 2008 | ASUS K8V-MX Motherboard
Cd rom message "no emulation" when booting the windows xp installer
when i install my windows xp professional i get a message prompting BOOT TO ATAPI CD-ROM: "NO EMULATION".... how can i fix this?Pls help me on this
Jun 07, 2008 | ASUS P4SP-MX Motherboard
AW-Q170A-B@ Sony DVD RW Atapi CD/DVD ROM drive
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
May 21, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Please Tell me, ASUS P4S8X-MX Problemn
First of all, try to reseat all the cables inside your computer just make sure there aren't any loose connections.
If that doesn't work you will have to reset your BIOS. (Follow the instructions in your motherboard manual.)
If even after resetting the BIOS the problem is not solved, you may have to replace your CMOS Battery.
Oct 18, 2007 | ASUS P4S8X-MX Motherboard
ASUS K8V-MX Motherboard Problem
you need to check all of your drivers, as 1 it sounds like your Graphics driver is not working well at all 2. you are not able to access your CD drives as your IDE driver is not compatible with VISTA and needs reloading follow the prompts on the following web page to get up to date drivers from the maufacturer http://support.asus.com/download/download.aspx?SLanguage=en-us Download updated VIA Chipset drivers for K8M800 + VT8237R to solve CD drive problem http://www.viaarena.com/Driver/via_hyperionpro_v513a.zip Audio drivers http://www.viaarena.com/Driver/vinyl_v700b.zip
Oct 07, 2007 | ASUS K8V-MX Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
ASUS P4S8X-MX Motherboard Logo
363 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
