Question about RCA Lyra X3000 MP3 Player
Unknown device My computer is reading the x3000 but as an unknown device. The dialog box says that no drivers are installed how do i fix this.
  • 8,596 Answers
Usually available from the company's website, but if not:
Start --> Control Panel --> Printers and Other Hardware --> System --> Hardware --> Device Manager - right click on the unknown USB device, click update drivers
I am assumig that you are using Windows XP
Posted on Jun 12, 2008
The computer can not recognize drive (unknown USB device).
Method 1 - Unplug Computer So how did I finally fix the problem? Well, if you are lucky, it's a super simple solution! Try this method first and if it works, you'll have saved a lot of time.
Simply unplug your computer from the power supply. Yes that is it! Note that this does not mean just turning off your computer using the power button because most modern computers don't actually turn off completely and the motherboard will still get power. This is useful sometimes if you want to remotely wake up a computer, etc.
The motherboard is where all of hardware of the computer connects to, including the USB ports. Sometimes the motherboard needs to be "rebooted" because things can go wrong, i.e. all or some USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should hopefully be recognizing devices again.
So first turn off your computer using the Shut Down option in Windows or pressing the power button and then UNPLUG the PC from the wall outlet. Let it sit for several minutes and then plug it back in.
Method 2 - Update Device Driver If Windows is not able to recognize the device, you may also see in Device Manager that the device shows up as an "Unknown Device". You can get to Device Manager by clicking on Start and typing in devmgmt.msc or by going to Control Panel and clicking on Device Manager.
In that case, you should right-click on Unknown Device, click on Properties, then the Driver tab and then click Update Driver.
If this doesn't work, you can also try to download the driver for your device from the manufacturer's website. If the USB device is just a flash drive, then it's probably not a driver issue. However, if you are installing a USB printer, drawing pad, etc, then it might be worth downloading the driver for that specific device.
Method 3 - Restart & Disconnect USB Devices The next thing you can try is to disconnect all USB devices and then restart the machine. once you have restarted, try to connect the USB device that was causing the problem.
If that particular USB port doesn't recognize it, try another one. If the device is recognized by a different USB port, there could be a hardware problem with one of the USB ports. If no USB port recognizes the device, then keep reading because it's probably something else.
Method 4 - USB Root Hub Another thing you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties.
Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box. If you have more than one USB Root Hub listed, you need to repeat these steps for each one.
Click OK and then restart your computer. Try to reconnect the USB device and see if it is recognized. If not, go back to the power management tab for each one and check the box again. If it does recognize the device, then leave them unchecked.
Method 5 - Connect Directly to PC A friend of mine ran into this issue and the cause ended up being his USB hub. He only had three USB ports on his computer, so he bought a hub where he could connect an additional 8 USB devices.
I guess this proved too much for his computer and it just started sporadically not recognizing various devices. After removing the hub and connecting the device directly to the computer, it worked just fine.
We haven't really been able to find any other solution to this problem other than reducing the number of items connected to the hub. Actually, one other solution worked, but it meant having to buy a new USB hub with more power.
If you are having this problem with Windows 8 or Windows 8.1, then you might be in luck. Microsoft has released a fix for Windows 8 not detecting USB devices properly. Make sure to install this hotfix if running Windows 8.
Method 6 - USB Troubleshooter If nothing has worked so far, you can download the Windows USB Troubleshooter Fixit tool. It's a free tool that works with Windows XP, Vista and 7.
You can either have the troubleshooter fix the problems for you or select the fixes yourself. I would just let it fix them for you since the choices can sometimes be confusing and technical for the novice user.
Method 7 - Update Generic USB Hub If you are getting the Unknown Device error in Device Manager, you can also try one other thing. Open Device Manager and then expand Universal Serial Bus Controllers.
You should see at least one item called Generic USB Hub. On some computers, you might see two, three or more of these. Right-click on the first one and choose Update Driver Software.
When the update dialog pops up, choose Browse my computer for driver software.
Jul 10, 2015 | Transcend StoreJet 25 750GB USB Hard Drive
No drive
Hello
The Creative Webcam Instant, like other computer devices, requires driver software. Once the driver is downloaded and installed, all you have to do is connect the webcam to your computer.
Click "Start" and then go to "Control Panel."
Click on "Category View" in the left pane of the "Control Panel" dialog box if you are in "Classic View." Click on "Performance and Maintenance."
Click on "System Restore" in the left pane of the Performance and Maintenance dialog box.
Click on the circle next to the wording "Create a restore point." Click "Next."
Enter a name for the restore point in the box under the heading "Restore point description:." Click "Create." The restore point will be created and your system will return to a working state within minutes. This process keeps your system safe in case there is an error.
Open your computer's Internet browser.
visit the Creative WebCam Instant driver's website.
Click on your computer's operating system name: or "Show all available drivers."
Click on the link "Download Creative-Labs WebCam Instant Creative WebCam Center v.1.71.02 driver."
Click "Save" when prompted. Navigate to the directory where the file is saved. Double-click on the file to open it.
Follow the on-screen prompts to complete the driver installation.
Plug the Creative WebCam Instant's connection cable into any available Universal Serial Bus (USB) port on your computer. Your computer will recognize the camera and process the camera's driver.
Open a chat client like Yahoo! Messenger, Windows Live or similar application.
Click on the "Webcam" setting within the chat client to activate and use the Creative WebCam Instant camera.
Nov 13, 2010 | Creative Labs Creative Webcam
Audio Driver for Acer System
There are 4 ways you can download and install audio drivers :
1.From Device Manager
(1).Click Start, type Device Manager in the Start Search box, and then press ENTER.
(2).In the Device Manager dialog box, expand Sound, video, and game controllers.
(3). Right-click the device, and click Scan for hardware changes.
You should see a message that a hardware device is being installed. Additionally, the uninstalled audio device is now present in Device Manager.
(4).Close the Device Manager dialog box, and then determine whether you can hear sound.
2.From the motherboard or installation CD - If your computer came with a motherboard CD, the audio drivers should be on the disk.
3. From manufacturer's website - If you don’t have the CD go to your computer manufactures web page to search for updated sound driver software. Read the instructions on the download pages carefully before installing.
4. Microsoft's Windows Update feature : If there are no updated sound drivers available, use Microsoft's Windows Update feature. Connect to the Internet and try the following items until Windows Update opens:
(1).Click Start, and then click Windows Update (if it is listed).
(2).Click Start, click Settings, and then click Windows Update (if it is listed).
(3).Click Start, click All Programs, and then click Windows Update (if it is listed).
(4).Go to Microsoft's Web site and click Windows Update from the Downloads menu.
Apr 22, 2010 | Computers & Internet
No sound in my laptop
Mar 19, 2010 | Toshiba Satellite R15-S822 Tablet PC
When i install the window xp than sound driver is not working so i want the sound driver . my pc product code is AZ001064
Mar 17, 2010 | Computers & Internet
I cant hear sounds in pc, how to install it?
Put driver cd for *********** board and update the Audio(sound) drive then restart your computer else it ask for restart give yes...
then sound will work
Regards
Murugeshkumar.k
Mobile:+919940214312
Mar 12, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
How can i download the installer for my creative vibra personal webcamera
1. Do not connect the webcam to your computer before installing thedrivers. If you accidentally begin installation with the webcamconnected, the Found New Hardware Wizard dialog box appears. Click theCancel button.
2. Then download this updated driver pack. It is azip file you must unpack to a folder.
http://blog.benjarriola.com/Vibra.zip
3. Click the names of the drivers and applications you want to install on your computer.
4. Follow the instructions on the screen to complete the installation.You may be asked, after an application is installed, if you want torestart you computer. Do not restart your computer until all thedrivers and applications are installed.
5. Connect the webcam's USB cable to an available USB port on your computer and wait for Windows to detect the device.
6. When the Found New Hardware Wizard dialog box appears, selectInstall the software automatically (Recommended), and then click theNext button.
7. When a Microsoft warning dialog box appears, ignore the message and click the Continue Anyway button.
8.Installation will complete.
9. Check the image in the Video preview pane of the Vibra Webcam CameraConfiguration dialog box. If it flickers or displays a series of darkbands, click the Cancel Flicker button.
10. Click the Finish button, and reboot if necessary.
When you boot up, you can check the Device Manager (ControlPanel > System > Device Manager). Click the plus(+) sign next to theImaging Device icon. The entry "Vibra Webcam" should appear.
Done!
Hope this helps :)
Chris (ziraffa)
Dec 23, 2008 | Creative Labs Vibra Webcam
I could not install the driver for pd1100 webcam on my windows XP machine. It say it is not licences with microsoft. What can I do? How can I install it?
Hiya Sivamathy,
1. Do not connect the webcam to your computer before installing the drivers. If you accidentally begin installation with the webcam connected, the Found New Hardware Wizard dialog box appears. Click the Cancel button.
2. Insert the disk. If you are definitely having problems with the drivers on that disk, then download this updated driver pack. It is a zip file you must unpack to a folder.
4. Follow the instructions on the screen to complete the installation. You may be asked, after an application is installed, if you want to restart you computer. Do not restart your computer until all the drivers and applications are installed.
6. When the Found New Hardware Wizard dialog box appears, select Install the software automatically (Recommended), and then click the Next button.
9. Check the image in the Video preview pane of the Vibra Webcam Camera Configuration dialog box. If it flickers or displays a series of dark bands, click the Cancel Flicker button.
10. Click the Finish botton, and reboot if necessary.
When you boot up, you can check the Device Manager (Control Panel>System>DeviceManager). Click the plus(+) sign next to the Imaging Device icon. The entry "Vibra Webcam" should appear.
Done!
Hope this helps :)
Chris (ziraffa)
Dec 21, 2008 | Creative Labs Vibra Webcam
Code 28 drivers
how do i fix code 28 for free
Apr 14, 2008 | Microsoft Windows XP Professional
I dnt hv cd installer
2. Then download this updated driver pack. It is a zip file you must unpack to a folder.
When you boot up, you can check the Device Manager (Control Panel > System > Device Manager). Click the plus(+) sign next to the Imaging Device icon. The entry "Vibra Webcam" should appear.
Done!
Hope this helps :)
Chris (ziraffa)
Dec 27, 2007 | Creative Labs Vibra Webcam
RCA Lyra X3000 MP3 Player Logo
217 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
