You can check the flasher switch inside the fuse box its easly replaced or you can check the brake switch located on the brake pedel upper part under the dash or it could be the turn signal switch it self Myadvice is start with the easyest test first first and that would be the flasher unit upllug it from fuse and try a new one if thats not it check brake switch
