Question about SanDisk Sansa c240 MP3 Player
RCA M4018A problem
I connect my mp3 player to computer with USB and my computer does not recognize my the device, and my mp3 player won't charge or turn on. What do I need to do?
  • evrednekchic Jul 01, 2008
    i plug my usb into computer and it wont recognize the mp3 player, if and when it turns on it says boot error please format unit
  • Anonymous Mar 20, 2014
    How do i get the player to charge
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 23, 2008
Coby mp3 player
Try to reset it if possible.
If the computer charges it then the computer recognizes it as a connected device. That's how usb works. It could be you need a new USB cable. Many devices that use USB for charging do not have the data leads connected in their cables. This is called a "vampire" connection as it only sucks 5 volts DC from the computer/charger .
Apr 03, 2014 | Coby MP-705 Digital Media Player
I plug my mp3 player into the usb port on my computer and it doesnt turn on to charge like it did before. i tried to turn on my mps player and it acts like there is no power. i just got this mp3 player and...
Hello
Check the connections on both ends to make sure they are attached securely. If the MP3 player is still not recognized, go into the player settings and change the Online Device from Media Device to USB Disk. Use a different USB cord if you have one because it could be broken and not allowing your computer to recognize it.
connect the device to a different USB port on your computer. If the MP3 player is still not charging, plug it into a wall charger. Try charging the Coby device overnight. If it still will not charge, the battery may be bad and you'll need to contact Coby for assistance
Apr 30, 2011 | Coby MP620 MP3 Player
Low Battery Mp3 player How do you charge it? Thought it was thru the USSB port on computer with computer on?
Hi dave holte,
It should be through the USB port, I don't think any players nowadays have separate ports for charging. Nevertheless, check if there is any port other than the headphone and the USB, because it never hurts to check. Does the computer recognize the device when you plug the mp3 player into the USB? It might be loose connection as well. Or maybe it is not set to be recognized as an MTP or Plug-and-Play device. Once you have it plugged in, go to My Computer (I'm assuming you are on PC) --> Device Manager and then scan for new hardware changes. Probably then you have to manually install the device and its drivers. But do check for the loose connections. Ask back if it doesn't work.
Mar 25, 2010 | RCA TH1611 MP3 Player
Where do i charge my rca m4018a at it has no spot to plug it into just a headphone part
You should of got a cord with it that has a usb at one end and a headphone thing at the other end. Plug the head phone end into your mp3. Then the usb into your computer. Wait a couple hours and it shoud say 'battery full'
Apr 23, 2009 | RCA OPAL M4001 MP3 Player
I don't know whether the battery is dead but it has been charged
When RCA makes the cords to charge and sync the device to the computer they used cheap parts and at the connector where you plug it into the mp3 player they don't solder the wires very well you cant repair it you nave to buya new one. VISIT LINK BELOW!!!
http://cgi.ebay.com/FOR-RCA-OPAL-M4008A-M4018A-M4002-M4004c-USB-CABLE_W0QQitemZ130291230332QQcmdZViewItemQQimsxZ20090304?IMSfp=TL090304122004r35488
Mar 25, 2009 | Dell DJ MP3 Player
MY RCA Opal M4204 Mp3 player will not turn on or be recognized by my computer...when I finally DO get it turned on..it says low battery but I have no way to charge it...HELP!!!
One plug it to the usb device of your computer
Hold down power button for 10 seconds.
Go to the RCA website and download the latest firmware.
Install the firmware and windows will find the player.
Keep it into the usb till its fully charged.
Dec 28, 2008 | RCA M4204 MP3 Player
My computer won't recognize my mp3/RCA M42 series
plug it to usb device of computer
Go to rca website update the firmware.
Keep it install to usb device and click on the firmware you just downloaded.
(do not remove from usb) You can format and update the firmware at same time that should make it like new.
Dec 27, 2008 | RCA M4204 MP3 Player
My MP3 Player
Hey,
You can go to Wal Mart and buy a universal car charger for
under $5 and it will work on computer to charge as well as
in the car.
Aug 06, 2008 | RCA Lyra RD1072 MP3 Player
Rca opal m4018a
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (moz-screenshot.jpgmoz-screenshot-1.jpghttp://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Feb 02, 2008 | RCA OPAL M4001 MP3 Player
My mp3 won't connect
that happened to me your computer might have a viris go to a friends or someone elses house and try it one there computer
Aug 05, 2007 | RCA OPAL M4001 MP3 Player
SanDisk Sansa c240 MP3 Player Logo
131 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
