here is nothing wrong in saying, "paper jam issue in canon printer " one of the most irritating issue. especially when you are going to print any import document and it got stuck in the middle of printing. when we face paper jam issue with our printer. we always try to contact to a technical expert for fixing such kind issue. while most of us don't know, you can fix paper jam issue in canon printer by yourself without inviting any technical person at your home.
If your printer has a paper tray, do not fill the tray. Overfilling the paper tray is frequently causes paper jams. Many printers have sliding mechanisms that allow different types and sizes of paper to be fed into the printer. If the slider is not correctly positioned, it can cause a paper jam.
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
I know the problem, Its the Exit paper sensor! if u make a short circuit on the pin 2 and 3 of the CN2 when the paper reaches the sensor it wont jam. Chainging the sensor resolves the continous paper jam or try to clean it!
If you are getting "Paper Jam check drawer two message" I would suggest you to check for any paper stuck inside the paper drawer two. If you don't see any paper jammed inside drawer two, you might also want to check out if its is stuck anywhere in the paper path. Removing the paper jam should fix the issue. Try cleaning the pick rollers (the rollers which pick the paper) in drawer two. This should help fixing this issue.
