Question about Haier hwr10xc6 Air Conditioner
Wall air conditoners
I would like to know how important is the depth of a thrue-the-wall air conditioner... I've found one that fits the lenght and width but is about 7 inches bigger in depth. How would this affect the conditoner and the room?
  • Anonymous Mar 30, 2014
    what are the proper specs so I do not have to change the wall casing
    Champion:
  • 254 Answers
As long as the width and length are the same you should have no differeance in cooling unless it is either larger or smaller in tonage.
Posted on Jun 12, 2008
How to remove face cover for cleaning
The front covers are usually snapped into place. Grab at top and bottom and pull. It should pop right off. GOOD LUCK FRIEND.
Sep 15, 2014 | Whirlpool ACC184PS Thru-Wall/Window Air...
Need manual for emerson quiet kool air conditoner model 12HT13?
I found this I hope it helps.
Performance BTU/H Cooling: EER: Voltage: Amps: Watts: Cooling Area (Sq. Ft.): Pints/Hour: Room Air Delivery (CFM): Plug Cap Amps: Plug Type: Dimensions Width: Depth: Height: Net Weight: Shipping Weight: http://www.appliancefactoryparts.com/airconditioners/emerson/12ht13.html#Manuals
Jun 02, 2014 | Emerson Quiet Kool 12HT13 Air Conditioner
Window air conditoner runs constantly
the termostat is broken . you need to change it
Jun 29, 2012 | Kenmore 76081 Wall/Window Air Conditioner
LED on Air conditoner showing E4. Also ice on outside unit, even though outside temp. in the 80sF (I am in Bermuda). No codes given in instruction manual - those found on web written in non-English !
If the air conditioner is the ryyd amerikool the e4 is OVERHEATING COMPRESSOR wants freon air, whether it is another brand might be a change of electrical phases, but send the best brand of air conditioner most definitely.
Aug 08, 2011 | Heating & Cooling
How much does this unit weigh?
dear sir
AMNA PTC153D35AR AIR CONDITIONER,S SPECIFICATION DATA ARE GIVING BLOW:
Dimensions & Weights Overall Width: 42" Chassis Width: 40" Wall Sleeve Width: 42" Overall Depth excl. Outdoor Grille: 21 1/2" Wall Sleeve Depth: 14 1/8" Overall Height: 16 1/16" Net Weight: 105 lbs. Shipping Weight: 120 lbs
Sep 29, 2010 | Amana PTC153D35AR Central Air Conditioner
I need screws too!!!
use a piece of thin wire to determine the depth of the screw hole so you will know the length of the screw you need.
Next carefully measure the width of the opening where you would screw it in.
Now go to a hardware store and ask someone to help you.
You will need pan head screws that fit the hole and depth you have.
Jul 17, 2009 | Simplicity for Children 4 in 1 Ellis Honey...
EE problem
It could be the control board. I found out that this model air conditoner has had problems with moisture getting in the control panel and shorting it out when it's humid outside. I have the part number if anyone wants it. It cost me about $45 from Sears Parts.
Jul 01, 2008 | Maytag M6Y12F2A Air Conditioner
Through the wall vs. window installation
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Jun 12, 2008 | Heating & Cooling
Haier hwr10xc6 Air Conditioner Logo
76 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
