Windows Vista should automatically detect and install devices attached to the computer. Simply connect the printer to your computer and power it on.
If the driver does not automatically install, you can follow the steps below to install a resident driver which is part of Windows Vista. The resident driver installation should only be used if the printer is not detected and installed.
1. Click on START, CONTROL PANEL and PRINTERS. 2. Click the ADD PRINTER button. If you do not see ADD PRINTER, right-click in the PRINTERS window and select ADD PRINTER from the menu. 3. The ADD PRINTER wizard window will appear select Add a Local Printer. 4. Select the port the printer is connected to from the drop down window beside Use an Existing Port, click NEXT. 5. In the next window select EPSON under Manufacturers and your printer model under Printers. 6. In the Type a Printer Name window, Set as Default is automatically selected. If you, have another printer that will be the default simply remove the check and click NEXT to install the driver. 7. Ensure the printer is directly connected to the computer and that the printer is ready to print. Click PRINT TEST PAGE to test the printer. 8. Once the test page has printed, click FINISH to exit the wizard.
*NOTE: -Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK. -As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The RED error light will flash when the printer is low on ink and go solid when it is out. -If the ink levels do not appear, click GET INK LEVELS from the MAIN tab of the printer driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
PRINTERS window and select ADD PRINTER from the menu. 3. The ADD PRINTER wizard window will appear select Add a Local Printer. 4. Select the port the printer is connected to from the drop down window beside Use an Existing Port, click NEXT. 5. In the next window select EPSON under Manufacturers and your printer model under Printers. 6. If Its Aa Photo printer Look For STYLUS PHOTO ESC/P2 Or If Its a stylus color look for STYLUS COLOR ESC/P2 THIS WOULD INSTAL A RESIDENT DRIVER!!! 7. Follow onscreen instruction!! 8. This would install a Generic Driver Which is called Resident Attached with your Operating System!
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus Photo R300 InkJet
the printer is jamming. message says printer error. see your printer documentation for clearing the...
(More)
the printer is jamming. message says printer error. see your printer documentation for clearing the error.
nem látja a nyomtatómat az operációs rendszer, kérem...
(More)
nem látja a nyomtatómat az operációs rendszer, kérem lehetőleg magyarul válaszolni, mert kicsi az angol tudásom, please, answer hungarian, becose I dont' speak english
Re Epson R300: Close cd tray is showing when I Turn on the printer and it is shut propley tryed...
(More)
Re Epson R300: Close cd tray is showing when I Turn on the printer and it is shut propley tryed turning it on and off still doing it.
