When I try to access the internet it says that it can't contact the internet after going through the router the tray icon says it has a good connection but can't access it.
    Problem Solver:
  • 10 Answers
Check your IP address..
check ur connection cables..
did you pay your connection bill?
contact your Internet Service Provider (ISP)...
if not solve....pls clarify everything...
Posted on Jun 12, 2008
How to Disable Internet Access?
Disabling Firewall Access for Windows Programs
  1. Go to the Control Panel. Click the "Windows" key or the "Start" icon, then click on "Control Panel". ...
  2. Open the Security Center.
  3. Open Windows Firewall settings. Open the "Exceptions" tab. ...
  4. Open the program and try to access the Internet.
http://schematicscom.blogspot.com/
http://electrotechnician.blogspot.com/
Oct 18, 2016 | Computers & Internet
How do i cHange ssid password on my computer
Looks like no one is going to jump on this one... The one reason I'd make the change is to block someone who has access to my network.
I don't advise the inexperienced administrator tackle this task either. However, you asked. The way you worded the question leads me to suspect you need some background too. I'll give you my best answer. Hang on!
A "Router" (wired or wireless) is the device that resides (electronically) between your Internet connected devices/computers/printers and the Internet. It was most likely installed by your Internet Service Provider. Computers (printers and other devices) connected to a router wirelessly (WiFi) need to know the name (SSID) and password (WEP WPA-PSK key) of the local wireless network (router). The name and key (password) is set at/on your router when it is first installed and can be changed by logging into the router as an administrator. Be advised once you change it on the router your computer(s) will be disconnected from the router and will be required to supply the new key to reconnect.
You didn't specify who your Internet Service Provider is or the manufacturer and model of your router so I can't be of specific help on exactly how to log into your router to make the change. You didn't specify your system's OS (Apple, PC Windows X, Lenux, etc). If you do not have the owner manual for your router get it before going any further. Get:
·Manufacturer and model info.
·Download the manual from web.
·Find, on your computer where you access the WiFi. On a PC:
A- "Right" click and "Open Network and Sharing Center" the "network Internet access" icon in the System Tray (Extreme lower right of Start Bar [where clock is at]) Usually the icon looks like a monitor. Once the "Network Sharing Center" is up:
B- Left click "See Full Map"
C- Once the map is displayed poise the mouse over the router's icon and it should give you it's address. It is usually 192.168.x.x (x= variable numbers). Make a note of the address. Accessing the router with a browser (such as I.E., Firefox, or Chrome) will require you know the router's administrator account and password. Enter the address where the "www.x.com address stuff is usually at.
D- Once you're in the router you can change the key. Make sure you enter it accurately. Once you've saved the changes you will be kicked out of the router.
E- Reconnect your computer with the new key by left click on the icon mentioned in "A" above.
NOTE: It is easy to lock yourself out of your own system. If you're not comfortable doing this call in a professional.
Good Luck
In His Grace
Elton
Mar 10, 2015 | Computers & Internet
The internet works just fine on the laptop, but when I try to get on with my laptop. Apparently I am connected to the network, but I can't get internet access.
I believe you have limited connectivity, just right click on the network connections icon on your system tray and the select repair so that you will get a new ip address.
Hope this helps
Thanks
Dennis
Nov 03, 2011 | D-Link DIR-615 Wireless Router
How to conect with wireless internet
The Network and Sharing Center in Microsoft* Windows Vista* can be used to set up a secure wireless connection to the Internet.
Note: If an Internet connection is not automatically made by the operating system, you may need to contact your access point (AP), broadband wireless router manufacturer, or Internet Service Provider (ISP).
Set Up a Secure Wireless Connection to the Internet
These steps assume that your network adapter; AP or router; and cable, DSL or another type of modem have already been physically connected and configured. They allow you to create a new connection and configure it accordingly.
Follow these steps to set up a secure wireless connection to the Internet.
Note: If a wireless profile does not exist, you will need to create a secure wireless profile before you can set up a wireless connection to the Internet.
1. Access the Network and Sharing Center.
2. Select Set up a connection or network.
3. Click Connect to the Internet.
4. Click Next.
5. Select Wireless. At this point, if the network(s) that are listed say that the network settings do not match the network requirements, as shown in Figure 1, create a secure wireless profile and then follow the steps again.
6. Select a network and click Connect. If you are not connected to the Internet, you may need to contact your AP/router manufacturer or ISP.
To access the Network and Sharing Center, use one of the following methods:
  • Start » Control Panel » Network and Internet » Network and Sharing Center
  • Start » Network » Network and Sharing Center
  • Right-click the network system tray icon (the icon that displays two computer monitors) » Network and Sharing Center
Jan 21, 2011 | Computers & Internet
I hooked up my D'link to modem and computer and connection is good. But i can't find it when i search on laptop wireless connection. I think you need i driver but i can't find one. Thank You
4. Click Next.
B52Computers
Jan 14, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Can't get my lap top to connect wirelessly to my router. Model # WRT54G2. The laptop says it is reaquiring the network address, but nothing happens.
4. Click Next.
Jan 10, 2011 | Linksys Wireless-G WRT54G Router
I got this computer for christmas and I cant get it to connect to any wireless wifi system. I dont know what I'm doing wrong. Could you please give me some instructions on how to connect it to a home...
4. Click Next.
B52Computers
Chris Thrash
Jan 10, 2011 | Computers & Internet
Internet connection setting for Belkin N wirelss modem router
If you can connect to the internet without the connection icon in the system tray, I think its fine. But if you really want to see the blinking icon, go to start>control panel>netweok and internet connection>network connection. There you can see the local area network icon. Right click on it and then properties. A new window will appear, make sure the "show icon in notification area when connected" is checked. Thank you and good day.
Apr 25, 2010 | Belkin (F5D8231-4) Wireless Router...
Brand new today. turned on and can't access wireless
It could be that your router is encrypting the information. This is easily fixed by changing a setting. To access this setting, click on the wi-fi icon in the system tray, right-click on your network, click properties, click the security tab, and specify the appropriate security and encryption type. Both of these can be found in the setup menu of your router. You can find out how to locate these settings by referencing your instruction manual that came with the router. Another way to fix this which is a much easier method is to go into the properties menu as specified before on the computer that can access your router, and click the "Copy this network profile to a USB flash drive". After that, plug the flash drive into your other computer and select the network setup wizard. After that a setup assistant will open and configure your settings exactly how they were on your other computer. Try this method first, and if that does not work, try the previous method I listed. Good luck!
Dec 26, 2009 | Acer Aspire AS5520-5537 Notebook
My laptop finds wireless router but will not connect to internet
Hi there. You may need to connect to the wireless network manually. What is the operating system running on your computer? If XP, you may follow these. (This is also applicable in other operating system, it may just vary a little) Right click the monitor icon showing on the system tray near the clock. Point the mouse in the icon and it will display the name if it is wireless network connection or network connection. Right click the icon and look for view available wireless network. If it is not showing, look for network connection. Right click and select "open network connection". Right click wireless network connection and select "view available wireless network" . Look for the wireless network you're trying to access or have connection.Highlight and click connect. If encrypted, you need to supply the pass key or security key twice and hit connect. It should allow you now to go online wirelessly. Please remember these, you should be able to go online wired. Make sure that there are other wireless computer connected to the wireless network you're connecting with and can go online wirelessly.
Hope this help :)
May 16, 2009 | Dynamode (R-ADSL-C4-W) Wireless Router
Computers & Internet Logo
David Payne
David Payne
