Question about Dell Inspiron 6000 Notebook
Error 0146 refuses to boot followed by this code
  • 24 Answers
If I remember correctly, this is a fault for your hard drive and it either has or is about to die. If you are under warranty, I would suggest calling Dell to correct the issue (they may be able to send you a new drive).
If not, you may be able to salvage your data with a 2.5" drive adapter (either IDE or USB) and another system. If you are out of warranty, you will need to purchase a new laptop hard drive , swap it out with the old one and reinstall your system, applications, etc. For this, you will need the system restore CD and resource CD. If you don't have the resource CD with the drivers for your system, you can download them strait from Dell but you will need a separate disks to install your operating system (windows I'm guessing) applications, etc.
If you were able to salvage your data, you can copy your data back to the system.
Posted on Jun 11, 2008
I have error 2000-0146 how to resolve this problem
Follow this link to Microsoft. Pay attention to the section regarding the "clean boot" procedures. http://answers.microsoft.com/en-us/windows/forum/windows_vista-system/error-code-2000-0146-unit-1dst-dell-laptop/8595604b-8cba-4ab8-b886-fad0725eb7cc?auth=1
I hope this fixes your issues. The clean boot is to allow you to identify the service that is causing your problem. Just be patient as there will be a lot of restarting and such. But the outcome should be worth it.
Jun 12, 2012 | Dell Vostro 1510 Laptop
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
2000-0146 error and oxc0000ed
Hard drive failure. If the system is under warranty, contact Dell for a replacement drive. If not under warranty, you can get a new drive here:
www.newegg.com
Jul 28, 2010 | Dell Inspiron 1501 Notebook
Does anyone know what code 0146 means?
This error code is related with the hard drive problem. There is a possibility of hard drive failure.
Mar 12, 2010 | Dell Inspiron 13 Notebook
Erorr code 2000-0146 ntldr missing ???
i could give you a long technical solution but the best is to re-install windows and select repair installation ,, it should fix the error ;)
Mar 10, 2010 | Dell Inspiron 1525 Notebook
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
My dell laptop gives me a error code of 0146 amd keeps rebooting
Error Code 0146 refers to failure to find or load NTLDR files, needed to run your operating system. Place your Restore disk in the DVD drive, power up the computer, hold down the F12 key till boot screen shows up. Boot from DVD and run Repair to restore these files.
Sep 25, 2009 | Dell Inspiron 1525 Notebook
Error code 2000-0146
I had the same problem and came across the following solution that worked for me as well:
Re: windows Vista will not start 18 Aug 2009 07:28PM I was getting a the same error codes and couldn't get Windows to boot up at all. I went to BIOS set up (restart your computer and hit F12 when the BIOS screen comes up), went to onboard devices and changed the SATA Operations from ACHSI (don't know how it got there) to the factory default setting ATA. Then I started up in "repair mode" (which was an option that was coming up when I tried to boot up before but never worked) - it went through a repair check and went to login screen.
Prior to finding this - I tried several things including start up from the Reinstallation disc, but nothing worked. I was ready to buy a new hard drive, but don't have to. Works fine!
Not sure what caused the problem to start with. It is an "Inspiron 1520"
Aug 03, 2009 | Dell XPS M1530 Laptop
2000-0146 is indicating a hard drive failure which is why it won't boot.
Jun 20, 2009 | Dell Inspiron 1501 Notebook
Code error 0146 and 0148
Both of these are hard drive errors. Error 0146 is a failed hard drive or bad drive sector, and 0148 is that thew machine is no longer detecting the hard drive. Basically, your hard drive has failed and will need replaced. Replace the hard drive and you will be set. The best place I've found to buy hard drives is at pricewatch.com, they have the best prices on the market.
Jul 29, 2008 | Dell Inspiron 1150 Notebook
Dell Inspiron 6000 Notebook Logo
639 people viewed this question
Alun Cox
