SOURCE: Canon PIXMA MP620 getting error code B200
This error is related to the Print head of your printer.
I recommend getting in contact with Canon to activate the warranty (if it's still under warranty) or getting it replaced. They usually are not expensive and may very well be cheaper than a new printer.
Do you have their number?
Hope i was of any help. If so, please rate me.
Thank you.
Pcsimples
SOURCE: how to fix error b200 on my canon pixma mp620
Replace your printerhead will do the trick. Had the same issue with my MP980
SOURCE: error B200 on canon PIXMA iP3300
1.
Connect the USB cable directly to a USB port on the computer
2.
Connect the USB interface cable
3.
Delete the printer (MacOS X), and then add it back again
4.
Reset the printer
5.
Try a different data cable
6.
Verify proper driver installation in Mac OS X
I hope it helps!!!
SOURCE: mp620 Error 5100 on canon is a Carriage Home
Hello i had the same problem with my canon pixma ip 3000 and i found
this steps to reset the printer and it work i hope it will help you in
yours.
Reset ip2000 / 3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
here is the link for other printers: http://www.cyber-ink.com/member-canon.html
Solution posted on http://www.fixyourownprinter.com/forums/laser/25975 by sguadalajara. My mp620 was printing fine at 600dpi but a 5100 error used to came up when i was trying higher resolutions. I followed the instructions above an the error disappeared. :)
