Question about Panasonic Televison & Video
AG-1970P no video input through svideo and split screen video on svideo output. Audio is fantastic.
    Master:
  • 638 Answers
Try a hard reset and then see.it will solve.
Posted on Jun 11, 2008
  • hemant somaiya
    hemant somaiya Jun 11, 2008
    try resoldering the vertical output IC that may be the problem why audio works and video doesnt. if this solution works for u rate this as fixya to encourage us to solve more and more problems like yours.good luck.
Black and white
The Lifestyle 38 has no HDMI output. It all depends on what inputs your TV has, which cable set up would be the best for you. Assuming that your TV has an SVideo input, you indeed can use the SVideo output of the Bose system, to get the DVD picture on your TV. However you will need to connect the audio output of the TV to the TV input of the LS 38 to get the TV sound to play over your LS 38. In case you don't have an SVideo connection on your TV, you can use the composite output of the Bose system and connect it to the video input of your TV (yellow in and outputs)
Dec 10, 2013 | Bose Lifestyle 38 DVD Home Entertainment...
Can I connect an active speaker to the Teac AG d7900 output
http://produto.mercadolivre.com.br/MLB-184407791-av-digital-home-theater-receiver-teac-ag-d7900-_JM
It would have helped to know something morwe about the 'active' speaker.I imagine its manual would tell you what it needs for input.
Active speakers are usually designed to be driven by volume-controlled Line Level inputs. This receiver has none except for the Subwoofer PRE Output.
Aug 17, 2011 | Teac AG-D7900 Receiver
Hmm.. I doubt you will be able to help me, and if you can, it won't be free, but here's my question anyway: any idea why when I try to connect an s-video cable from my harman kardon avr 130's Video 1...
Well, use the "Monitor Out" jack on the receiver, as that is what it's designed for.
Is there a jack labeled "Video 1 Input" or only "Video 1 Output"? It could be that the Harmon Kardon folks have a weird way of labelling so that "Video 1 Output" is actually an "input" to the amp that is then fed thru the "Monitor Out" jack. It will take some experimenting on your behalf. Some units will also NOT take an input or output thru the S-Video IF you have a composite cable connected to the (yellow) composite video jack for that same point, so make sure that is disconnected if you want to use the SVideo. Also, sometimes there is a menu setup in your monitor where you have to decide between Composite video or SVideo or Component Video, so check that in some cases as well.
Let me know what you find out.
Mar 12, 2011 | Audio Players & Recorders
I would like to run my TV sound out of my TEAC AG-D9100. Can I connect my TV sound output to the VCR/VIDEO4 input without a video input and then switch to VCR VIDEO4 to get the output sound? I have the...
Yes, and if you have a cable/sat/dvr box why don't you just run ITs best TV-related audio into the receiver without watering it down through your TV?
I'm not so sure that running the TV video through anything else serves any purpose. Once TV has it where else do you need it?
Apr 30, 2010 | Teac AG-D9100 Receiver
I got a teac ag-v8060 audio/video surround receiver and I'm tryin to hook up some surrounsound speakers along with a jbl g cinema sub can you describe where the wires go in the back of receiver? The sub...
On the back of the receiver, there could be "pre out-subwoofer". If your subwoofer has the same type cable input, that would indicate it is a powered(amplified) sub. Connect those two. If subwoofer only has red/black speaker inputs, it is a passive sub, which means spkr signal runs thru it and then to your main left and right spkrs.. Run your receiver main or front spkr left (red/black) and right (red/black) to those corresponding sub inputs, and then sub spkr outputs to each of your main left/right spkrs..
For surround, on the back of the receiver, there should be spkr outputs (red/black) noted as "rear".
Just make sure red to red, and black to black.
Hope this is helpful.
Apr 28, 2010 | Teac AG-V8060 Receiver
How to connect pc to tv what do ineed or have to do
You have 2 options:
1) Buy a video card that has either RCA video output or HDMI output (depends what kind of connector your has). This is much cheaper, might cost about $20 or up.
OR
2) Buy an external USB video device that will destribute the singal to TV output, but it costs from $59 to $125.
Aug 02, 2009 | Computers & Internet
Onkyo TX-SR875
My mistake, HDMI in is not routed to any other output but HDMI out
Oct 04, 2008 | Onkyo TX-SR875 Receiver
No picture
I have my television outputs connected to the inputs on the ILO. I then select that set of inputs with the SOURCE button rather then using the built in tuner. Make sure you connect the Video closest to the audio inputs(or... least confusing, try the three front inputs) Hook antenna to tv
Jun 28, 2008 | iLO DVDR05 DVD Recorder
No audio on ag 5700p
check input voltage on IC 4003, replaced power supply
Mar 26, 2008 | Panasonic Audio Players & Recorders
Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Jan 07, 2008 | Teac AG-D9320 Receiver
Televison & Video Logo
22 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
