Question about Panasonic SC-HT800V System
Front speaker SB-FS803
I have a broken plastic switch thing where the speaker wire is supposed to be inserted. Because it is broken, it won't put pressure on the one wire, and I am getting no sound form the speaker. Is there a way to fix this or get a new cartridge to put into the speaker so that it will work, or do I need to just buy a new speaker? If a new speaker port is available, is it difficult to put in?
Thanks
Star
2 Suggested Answers
redhead7377
  • 51 Answers
SOURCE: My receiver for the Panasonic-SA-HT800V is toast
ebay? the speakers can only be used with this model..unless you strip the speaker wire...
Posted on Jul 25, 2008
Polk Tweeter on RT 1000i
it sounds like its the cross over
Mar 25, 2013 | Polk Audio RT1000I Speaker
Rpm won't go over 4000 and will not do over 30 mph
2002 GMC Envoy Car Stereo Wiring Chart
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jul 23, 2012 | 2001 Dodge Stratus
I have a 1990 Celica, trying to put in new radio. Got everything wired up correctly, Constant - blue/yellow, acc - gray, ground - brown and it won't come on. Radio fuse (top center 15 amp) is good,...
You have it right. Use a 12 volt test light to see if there is power between the gray and brown wires when the key is on. If there is power there, you may have got hold of a bad radio.
1990 Toyota Celica Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow, connects to yellow
Radio Switched 12V+ Wire: Gray, connects to red
Radio Ground Wire: Brown, connects to black
Radio Illumination Wire: Green, do not use
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Oct 29, 2011 | 1990 Toyota Celica
I just got a 92 ultra and the guy i got it from said the cruise worked before he put grips on and now it dose not can you help to adjust
When a problem is encountered after something has been done go to the last thing you did ( put grips on) and check what was done. Look for pinched wires binding cables whith housing open and closed. A card board spacer has to be inserted in crack between front brake lever and housing to retain internal piston in handle bar assy. or damage to front master cylinder piston can result (brake won,t disengage as plastic piston gets stuck.
Dec 01, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
Gauge cluster lights won;t light - replaced cluster, dimmer switch - did put new stereo in car? Fuses, bulbs all good. What could be the problem?
When you put the stereo in, what did you do with the red wire with a green stripe? The aftermarket radios don't always use these, so you have to wrap the ends, depending on whether or not you used a wiring harness. If that wire is shorted on the chassis, it will blow the dimmer fuse.
1995 Honda Accord Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/White
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Red/Green
Car Stereo Antenna Trigger Wire: Yellow/White
Car Stereo Amp Trigger Wire: Violet/Red
Car Audio Front Speakers Size: 5 1/4?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 6 1/2?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Nov 28, 2010 | 1995 Honda Accord
94 BUICK LESABRE RADIO WIRING
1994 Buick Lesabre Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Stereo Radio Illumination Wire: Gray
Stereo Radio Dimmer Wire: Brown
Stereo Radio Antenna Trigger Wire: N/A
Stereo Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6′ x 9′
Left Rear Speaker Wire (+): Brown
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
May 15, 2010 | 1994 Buick LeSabre
NO DISC message
I assume that problem is dirt on laser lenses. If you don’t get any result after this, than you can replace receiver with new one. If you want to use your existing speakers with new receiver with integrated amplifier, you must pay attention on wattage, to be same like old one (i.e. 100W), and also resistance (i.e. 4 ohm). If it’s same like old receiver, you should have no problem. Good luck.
May 06, 2008 | Panasonic sa-ht800V Home Theater Audio...
NO DISC message
Open up the unit and clean the lens using a cotton swab and alcohol. If that does not resolve the problem, try a music CD and report the results here. I suspect that the optics have begun to fail. If that is the case, the music CD will play but a DVD will not. The optics assembly is available (part # RAF3023A-1) for about $60.
Dan
Panasonic SC-HT800V System Logo
157 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
