Question about Ricoh Office Equipment & Supplies
ERROR CODE 0550H ON RICOH 3310LE FAX - Ricoh Office Equipment & Supplies
5 Suggested Answers
podita
  • 324 Answers
SOURCE: time chance pcu
here you will find the manual read to resolve this issue, thank you,
http://pdfdatabase.com/ricoh-3310le-manual-repair.html
it counts to vote, have a wonderful day
Posted on Mar 25, 2010
checkitright
  • 1362 Answers
SOURCE: Printing Confirmation of sent fax days later
here is the manual
http://www.retrevo.com/s/ricoh+3310le+manual
good luck
Posted on Jan 04, 2008
SOURCE: ERROR CODE 0550H
tech
Posted on Sep 25, 2008
  • 62 Answers
SOURCE: Ricoh fax error #400
Possibly the fax line is open (busy). Try ringing the fax number, see what you get. Try unplugging the fax and plug a normal analogue handset into the line. See if you are getting a dial tone.
If not, then the cabling or line are faulty. Talk to your carrier. If yes then replace the cable on the fax (if possible) or have it looked at.
Posted on Mar 04, 2009
FixinFax
  • 3085 Answers
SOURCE: faxes from a ricoh 3310LE are not going through.
It is not a fax machine
It is set to MANUAL RECEIVE
It is on a DIGITAL phone line.
Posted on Sep 04, 2009
Fax Machines Ricoh Fax 4430NF error 0550H "call
Easy !
Press yellow button
Enter numbers: 107
Push red button for 5 seconds
Press number: 1
Enter: 5#810#
Press number: 1
Press (Half)tone and OK button at the same time for some seconds.
DONE ! Greet Barry
Feb 01, 2011 | Ricoh 4430NF Laser Fax
Ricoh 3310l fax shows error code 0390H in display. Anyone know what this means?
I've never seen a message like that with the 0390H code. There is no mention of that code in either the user manual or service manual. The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that problem.
If the new PCU doesn't fix the problem, you might want to try calling Ricoh for support, since their documentation doesn't mention that code.
Jun 11, 2010 | Ricoh 3310LE Plain Paper Laser Fax
Time chance pcu
Mar 25, 2010 | Ricoh 3310Le Fax Machine, FAX3310Le...
Won't always transmit the fax.
what is the error code? the solution is to find the error code and what it means in the manual.
Oct 22, 2009 | Ricoh FAX3900L Plain Paper Laser
Fax not received
No, just the fax phone number.
Mar 09, 2009 | Ricoh 3310Le Fax Machine, FAX3310Le...
Time to change PCU- Ricoh 3310L
Go to this page http://www.ricoh.com/ and find the official ricoh service department for your area
Nov 07, 2008 | Ricoh 3310Le Fax Machine, FAX3310Le...
262 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
