Question about Whirlpool RBS305PDS Electric Single Oven
WHIRLPOOL GY396LXPB00 MIGRATION CONTROL PROBLEM
I am having a problem with my WHIRLPOOL GY396LXPB00 MIGRATION CONTROL. The lock symbol is present, and will not clear, we tried every button on the keypad, and the lock symbol will not go away.
  • Juiceandjazz Oct 10, 2008
    I had the same problem last year, some how it went away, and now it is back.
  • 725 Answers
Press and hold at the same time child lock ( 2nd button in the row of buttons under the clock. and cancel ( bottom button far right ) hold until lock light blinks (10 -25 sec) hope it helps
Posted on Jun 12, 2008
On a whirlpool double oven what does F2 error mean and canit be fixed
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. If present, replace control board (clock). For SELF CLEAN models, check door lock operation. Check sensor, sensor harness, and the sensor harness connection at sensor and oven control. Also check for any causes of high resistance in the oven temperature sensor circuit. Remember: The oven control board (clock) measures resistance of sensor circuit, not actual oven temperature.
Nov 23, 2016 | Whirlpool Ovens
A key symbol is showing. How do we unlock
Hello. Look on the control panel for a button(or set of buttons) that are usually pressed for 4-5 seconds. The button(s) will have a lock symbol or the word "lock" beneath it. You press and hold the button(s) until the lock symbol goes dark. That tells you the lock has been disabled.
Nov 03, 2015 | Ovens
Whirlpool range LOC
This may be a child lock feature. Look for a padlock symbol on the panel. Usually you have to press and hold this for a few seconds to shut off this feature.
Feb 28, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    OVEN TURNING OFF BY ITSELF. I THINK THE CODE ON IT IS SAYING F2
    Hi!
    The F2 code means Oven Temperature Too High. When this code is present do the following:
    1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
    2. For SELF CLEAN models: check door lock operation.
    3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
    Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
    A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
    Nov 02, 2010 | Whirlpool SB160PEE Gas Single Oven
    Door lock symbol flashes all the time
    this may not be very helpful Gaggenau can be really tricky
    ive seen this once before a long time ago but its worth a shot
    the connection from the lock sensor might be loose
    you should be able to unscrew the control and roll it up
    right behind it you will see the lock and connections
    jiggle em
    like i said a long time but i believe the connection on the control board is green
    Oct 07, 2009 | Ovens
    Lock symbol on oven won't go away
    Unplug for 60 seconds and plug back in
    Apr 30, 2009 | Ovens
    Whirlpool electric oven problem
    thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
    Sep 22, 2008 | Ovens
    Whirlpool Range GY396LXPB00
    shanco, is your clock working at all, does it display. If not, you have a thermal cut out on the back of that oven. This runs through the neutral side of that clock. If that TCO is open, the clock and display will not function. Part number 4451442. Very inexpensive. You can look it up at repairclinic.com for a price. They will have a picture of it. Now I'm going by model number gy396lxb00. You have to remove the back panelto get at it. According to the schematic Im looking at it looks to have 2 red wires going to it. Catriver
    Jan 04, 2008 | Whirlpool RBS305PDS Electric Single Oven
    Whirlpool oven issue
    Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
    Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
    Whirlpool RBS305PDS Electric Single Oven Logo
    256 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Sal DeAngelo
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
