Question about Hotpoint First Edition FEW10P Front Load Washer
Washing machine broke
When i put the washing machine on, it is only on for a couple of minutes then turns of, i have been told this is a designer fault, but do not know what to do, or how it can be fixed.
    President:
  • 1,294 Answers
See if your faucet on the wall is open. Designer fault??
Posted on Apr 01, 2009
The spinner won't work
If it is a top-load (I'm not sure about front loaders) the direct drive motor coupling has broke. It's designed to break (for safety reasons), and will eventually break due to fatigue. If the washer washes and drains, it is usually this part. A $10 part which takes 10 - 30 min to replace. Here's a link to the part and some other common parts.
Washer Parts Same Day Shipping Millions of Parts
Apr 09, 2016 | Washing Machines
Will not agitate after water fill up. Motor makes whining sound.
It sounds like it could be the coupling that has worn or broke, to verify this put the washer in spin, let it drain the water out (if it will) then turn off the timer or open the lid, wait 10 seconds or so then start back up in spin. If the washer just whines then it is most likely the coupling. I have put together some instructions on this if you follow this link it will tell you more about it and how to replace it if you wish. Let me know if this helps.
http://www.fixya.com/support/r4670549-drive_coupling_replacment
May 06, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Drum wabbles more than normal. Balance
move the cloths around to balance the load better or put less in the machine
Aug 24, 2009 | Amana LW8203
Drum isn't turning but the drive belt is ok. taking in water and draining water fine.
the coupling on the motor ia broke you have to take the front off the washer and take the pump off there are clips you have to take off pull the motor out and the rubber coupling is right you will have to buy another coupling they cost about $10.00 then you put it back together. Tommy
Jul 17, 2009 | Washing Machines
Intermittent agitation and spin, mostly just hums, burning smell after replacing drive coupling
sound as if the motor or someting else is sticking release the belt on the motor. check belt for damage. check motor by turning it by hand to see if it is free.
May 12, 2009 | Washing Machines
Problem with Kenmore Washing Machine.
IF your coupling is broke then put a new one on and see, but without a coupling then you dont have a washer period. Whirlpool is very good make if a new coupling does not work and you can hold the tub while it is spinning then you have a bad basket drive. but put a coupling on and then put it in spin, bypass the switch with a ink pen or something and try holding the tub if you can then its the basket drive if not your good to go.
Apr 19, 2009 | Kenmore Washing Machines
Kenmore Washing Machine 110.20722990 Will not agitate or spin. Took it apart and found a broken coupling between motor and gearcase. Does this mean gearcase is out?
no u just need to replace that motor coupling u just take pump and motor off take broke coupling off put new back on be as good as gold
Apr 19, 2009 | Washing Machines
My loud washing machine
open it up you most likely broke a drive Coupling
May 31, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Hotpoint ultima vtd20
Had the same problem. Take the back off (after the usual precautions, unplug, turn water stopcocks to off). Look at the bottom of the motor, there are 2 thin brown wires loosely held together with a short white protective tubing. It is likely that one or both of these wires have come loose from a Bakelite type connector going into the motor, near where the belt rotates. This is the feedback tachometer to the control unit. Basically it tells the machine how fast the motor is going. When the machine starts to fill, the motor turns a couple of times, no feedback therefore the control unit stops the cycle and drains it. I tried to solder the wires back onto the connector but when I refitted the motor the joints broke again (maybe I was too rough but the connector isn?t designed for re-soldering). A replacement motor did the trick ? but check out Hotpoint?s service plan, it lasts for a year and they will replace the motor under that plan. If a different fault develops they will replace the machine for a new one. Hope mine breaks within the year?good luck.
Mar 11, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint First Edition FEW10P Front Load Washer Logo
46 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
