Question about HP Compaq Presario V5000Z Notebook
Laptop won't start-up
My laptop won't startup, say's that it can't find normaliz.dll. need to re-install.
    Genius:
  • 2,028 Answers
Try running your recovery disc.
Posted on Jun 11, 2008
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
What does this message on my pc mean?Error in c: windows \ system32 \ spool\ drivers \ w32x86\3\dlcd time. Dll missing entry: run dll entry
Time.dll was probably installed along with some software that came with the HP printer.
As time.dll is shared with other applications HP may have removed it during the uninstalling process and either some oter application is looking for it or a command to open it has been left behind.
As you say the Dell printer is working well so have alook in your StartUp folder (Documents and Settings/User/Start Menu/Programs?StartUp) and delete any reference to that file of HP Printer.
Also look under StartUp by Clicking Start > Run and typing msconfig and uncheck andy reference to HP or the file.
If it turns out another pallication needs the file then reinstall that application.
Jan 29, 2012 | Dell Computers & Internet
When I boot my computer, which runs Windows 7 64-bit, I get the RunDLL message, "LogiLDA.dll specified module could not be found."
I have the same problem logiLDA.dll not found. Look like this is a Logitech file that is for Logitech Download Assistant. You can go to start (type) msconfig and find it on the startup tab and disable it, I'm currently looking for a solution.
Mar 11, 2011 | Computers & Internet
My of has a run dll issue and won't open any programs nn short cut no start menu how do I install missing ?
Option 1:
There are 3 step to repair run dll error
I think your computer is already very dangerous, and you should fix it immediately. I had the same problem with you, it bother me for a long time. I have searched many ways online and found that the following method is the best, my friend had run dll error too, he also quickly fix run dll error with the following method. I think you should try it, I hope it can help you:
1: Download a run dll error repair tool,install this error repair tool.
2: Open run dll error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair run dll error.
Here are the url of run dll error repair tool:http://www.repair-dll.com/
Option 2:
Run MSCONFIG at the run prompt. Check all the tabs (especially the Startup tab) for that file and uncheck it.
XP does have several files that it reads at startup (including AutoExec.bat and Confiog.sys for compatibility) and these can ALL be accessed from MSCONFIG.
You can also boot u io Safe Mode and run Malwarebytes if you have problems here.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 13, 2011 | Compaq Presario CQ60-220US PC Laptop
Normaliz dll is missing
You can try downloading and placing this dll in the windows/system32 folder
http://www.dll-files.com/normaliz.zip?0VKhRCYFgS
Let me know if that works ;)
Sep 25, 2010 | Microsoft Windows XP Media Center Edition...
Message read/ missing export user 32.dll update layerd window.
Greetings,
To resolve this issue, follow these steps:
  1. Restart your computer using the Windows 98 or Windows Me Startup disk.
  2. On the Startup menu, choose the correct CD-ROM support for your computer.
  3. Type the following commands, pressing ENTER after each command:
    c:
    cd <windows>\system
    ren user32.dll user32.dlx
    ren gdi32.dll gdi32.dlx
    ren winmm.dll winmm.dlx
    <ramdrive>\ext.exe
    where <windows> is the name of your Windows folder and <ramdrive> is the virtual drive created by the boot disk (probably e:\ or f:\).
  4. Type the following line, and then press ENTER: For Windows 98:
    <CD-ROM drive>:\win98
    For Windows Me:
    <CD-ROM drive>:\win9xwhere <CD-ROM drive> is the drive letter assigned to your CD-ROM drive. Note that this letter may be different when you boot your computer with the Windows Startup disk.
  5. Type the following line, and then press ENTER:
    user32.dll gdi32.dll winmm.dll
  6. Type the following line, and then press ENTER:
    <drive>:\<windows>\system
    where <drive> is the drive on which Windows is installed, and <windows> is the folder containing Windows.
  7. Review the information displayed. If it is correct, press Y.
  8. Type the following commands, pressing ENTER after each command: cd
    ren Cmapieng.vxd Cmapieng.vxx
  9. Restart your computer.
  10. Once Windows has restarted, run the Defragmentation application.
When Ext.exe has finished extracting the files, follow these steps:
  1. Remove the Windows 98/Me Startup disk, and then restart your computer.
  2. Press and hold down the CTRL key as your computer restarts. On the Windows 98 Startup menu, select Safe Mode.
  3. After Windows starts, on the toolbar click Start, point to Settings, click Control Panel, and then double-click Add/Remove Programs.
  4. On the Install/Uninstall tab, click any utility that you have installed, and then click Add/Remove to remove the utility. Repeat this step to remove any utilities you have installed.
  5. On the toolbar click Start, point to Settings, and then click Taskbar And Start menu.
  6. Click the Start Menu Programs tab, and then click Remove.
  7. Double-click Startup, click the appropriate entry, and then click Remove.
  8. Click Close, click OK, and then restart your computer.
  10. In Microsoft System Information, on the Tools menu, click System File.
  11. Click Settings, on the Advanced tab, click Restore Defaults, and then click OK.
  12. Restart your computer.
Sep 20, 2009 | Microsoft Windows 98 for PC
When i startup my laptop i get massage that i lost m3plugin
Windows errors related to m3plugin.dll?
If Windows is unable to run applications due to a .dll error, this .dll may be missing or you may have registry error. Such errors can heavily influence the performance of your PC. I strongly recommend that you run this free registry scan.
Here you can download m3plugin.dll free of charge. The file is compressed so you need an unzip software in order to use the file. We recommend you to read the tutorial how to unzip and install the files. Use the link below to start downloading m3plugin.dll.
arrow_w.gif Recommended: Fix m3plugin.dll Errors arrow_w.gif Enhance your PC-speed: Free Performance Scan arrow_w.gif File description: MyWebSearch Idle Monitor, v. 1.0.3.2 arrow_w.gif Filesize to download: 2.4 kb
download_icon.gif Click here to go to the download of m3plugin.dll
Jun 09, 2009 | Intel Motherboard
M3plugin
good morning
my m3plugin.dll file is missing. how can i reinstall it?
Oct 27, 2008 | Intel Motherboard
Dll file have error
Hi alexistech, the wininet.dll & newdev.dll are windows fies. You can try this link to fix your *.dll files.
http://www.dll-files.com/dllindex/dll-files.shtml?normaliz
Luck!
If this helps, please let me know.
Need more help just post your questions here.
Mike
Apr 17, 2008 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
HP Compaq Presario V5000Z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
