Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint Aquarius WD440, Rinse Hold, Time Saver and On/Off light flashing
My machine occasionally freezes. It usually occurs during the final spin stage - and the machine can only be reset by unplugging it. I've spoken to a hotpoint engineer (by telephone) who suggests that the fault code displayed (ON/OFF light, Time Saver & Rinse Hold flashing) indicate a short somewhere. It's completly intermittant, and has not improved despite cleaning out the filter bowl, pump, standpipe etc. Does anyone have a suggestion as to a) what exactly this fault code indicates? and b) what repair(s) are needed? Thanks for your help.
  • Damian Murphy Jun 15, 2008
    Update:
    Thanks Richie,
    I've removed and inspected the control board, cleaned the switches with switch cleaner, cleaned all contacts and inspected all wiring for any signs of damage - machine back together and after 3 successful washes the fault is back!
    I'll contact hotpoint tomorrow to arrange a service visit to get the board changed.
    Thanks again for your help and advice,
    B/Rgds,
    D.
  • Anonymous Mar 26, 2014
    MACHINE NOT WORKING 1400 /800 / RINSE HOLD LED FLASHING
    Genius:
  • 1,036 Answers
This is typical of a control board problem.
About 60% of the time they can be repaired, but it's easier to replace it than keep testing.
If you are competent at electrical repairs, then read -on, otherwise order a replacement, and have it fitted.
Isolate supply.
Remove top cover by removing screws at top rear, slide cover rearwards.
Control board is on right at the front.
Test connections - remove and replace all connections, checking for signs of arcing.
Check main wiring loom to motor for integrity and damage.
If no signs of damage, remove control unit board, and examine for arcing or poor contacts, overheated components or damage.
If everything still looks ok, a replacement control board should be fitted and the machine tested.
Hope this helps.
Posted on Jun 11, 2008
On/off rinse hold & TIME SAVER LIGHTS FLASHING WON'T DO CYCLE
For error code definitions on Hotpoint, Creda and Indesit machines use this link
Mar 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint washer dryer lights flashing
Check first the thermal fuse.
Test heating element to ensure is not grounded, and staying always on. Test the fan and ventilation system.
If you find no fault in there , then test the timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 23, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
My hotpoint aquarius wd440 washing machine - flashing lights ?
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
Oct 18, 2008 | Hotpoint Aquarius WD63 Front Load...
u might have a blockage in the drainpipe. hope it helps. good luck!
Jun 16, 2008 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aquarius wd440 has flashing lights
First of all try cleaning the filter inside the back as described by others if this does not work there is a filter in the top. how you clean this is quite easy. all you do is remove the top of the machine by undoing the 2 screws at the back then pull top top backwards when you have removed the top you well see a large metal casing on the left if you are looking from the the back of the machine the filter is in there to remove the casing you pull the small pipe off then undo 5 star headed screws then gently pull the casing off noteing that there is a large pipe at the front when you have remover the casing you will see the filter (the small pipe you removed at the start fits on this filter) clean the filter then put it all back together.
Jun 14, 2008 | Hotpoint Aquarius WD63 Front Load...
AQUARIUS HOTPOINT WD440
How many times does it flash.
it still sounds like you have an obstruction in something.
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD440 Error
Remove the white plastic cover on the back near the bottom. To the right as you look at it their will be a black concertina pipe with a hose clip on its top edge. Undo this and pull the pipe downwards to reveal the filter. There will be a plastic ball inside (which is supposed to be there) remove this and clear out the cr*p.
Re-assemble as removal.
That should fix it
Jul 26, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
1,293 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
