Question about Whirlwind FH-778 Air Conditioner
Air conditoner i got a central ac unit and it was blowing cool air all night then today it quit and turned warm and i heard a buzzing sound from the unit i wonder what is wrong with it?
  • 1 more comment
  • hayoo Jun 22, 2008
    My outside AC unit was working just fine. The only problem I had was the air would stop blowing from my vents after running it for a while. I called a tech to see if he could tell me what the problem was, and he said my a-coils were probably freezing up and it needed freon. I looked and sure enough, there was frost on the pipes. They came out and charged the unit and the air was blowing much better from the vents. Around midnight, the outside AC unit quit working. I called him the next day and he said it must have blown a fuse. I told him I may need him to come back out to see why it was doing that. When I got home, I saw it had tripped the breaker, but when I reset it, it made an awful noise. I called him and got a recording, and he has never returned my call. I had an electrician come out and he said it was my unit, not my breakers. I called another hvac tech and he said my compressor went to ground(?) or something like that, and it was probably due to reon getting on the wires. The capacitor was just laying on the ground inside the unit.
    Needless to say, I was fuming because I feel they were the cause of it going to ****, he wouldn't answer my calls or call me back, I can't afford a whole new unit, AND it's HOT!!!
    Any opinions on this would be greatly appreciated! Thanks!
  • burzerko
    burzerko May 11, 2010
    Are you able to see ice on the unit anywhere inside the home or outside at the condenser?
  • Mike Apr 28, 2013
    Most likely a older unit. Unit must of had a small leak somewhere and he added freon. That caused the compressor to draw more power or current which caused the breaker to trip. Could have a dirty condenser coil or fan running slow causing higher current draw. His gauges show show what system is doing.
    Master:
  • 461 Answers
I agree with there is a load issue...To much freon in line will cause the noise and also not enough oil in freon...The more harder that compressor works the higher you electric bill. If you dont know what your doing call someone.
Posted on Aug 13, 2013
    Champion:
  • 254 Answers
Sounds like your compressor is locked up or is running under a sevre load you would be best to call a professional
Posted on Jun 22, 2008
When i turn on the ac insted of blowing cool air it blows warm or hot air
Your central cooling unit is not performing correctly. You will need to take this to a shop and they will fix it for you.
Apr 17, 2011 | Chevrolet Astro Cars & Trucks
Central heat does not blow hot air, just warm air weakly
Sounds like some of the elements are not working. You being in Florida they may not have put very many elements in. It was 61 degrees last week. I know because I'm a Dolphin Fan. You will need a current sensing meter to check the elements.
Jan 04, 2010 | Heating & Cooling
AC BLOWS WARM AIR
Cooling comes from what is done outside, if air handler is blowing and you are hearing a sound , may be in the duct work. If you feel warm air in cooling mode then the outside unit is the prob, need more info
Jul 25, 2009 | Heating & Cooling
Ac fan not turning on I can ''stick start it'' but which direction?
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Jun 26, 2009 | Carrier Heating & Cooling
Air conditoner quit blowing cold air while driving home
you can try recharging the system...it's a fairly simple process and freon can be purchased at any parts store. here is an overview:
http://www.aa1car.com/library/ac_recharging.htm
Jun 24, 2009 | 2004 Ford F150
My central ac unit is blowing air that is cool but not cold
Ek chiz sukha ho to 2kg gila ho to 1kg and jal jaye to 3kg its urgent please
May 18, 2009 | Heating & Cooling
Outside Unit blowing air but not cooling and slight buzzing sound
The compressor is not coming on and some part of that unit has failed. Do you hear any clicking sounds along with the buzzing sound? Recommend that you shut the unit down (remove power from it) until a service tech can listen to it try to start up.
The power company-installed load management system is probably a red hearing. That system will either fully turn off the unit or allow it to turn on/start up.
May 08, 2009 | Heating & Cooling
Central air conditoner unit doesnt blow cool air into home has some ice on the inlet heat and cooling lines going into the central air unit
Change the furnace filter. Make sure you use a cheap one when air conditioning, as the better ones restrict airflow when they filter out so much stuff and then plug up, not allowing enough air to pass over the cooling coil in the furnace's air plenum. Turn the A/C off for a few hours (with only the furnace fan on if possible) to melt the ice off the cooling unit inside the furnace.
Sep 01, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
151 people viewed this question
Top Whirlwind Heating & Cooling Experts
Dennis Boxerman
Bill Long
Dan Webster
Dan Webster
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
