First off , you are doing all that wrong.
(baring heat sink removal and reading top of chip.!!.. with eyeballs.
or run program CPUz (google it, it actully scans the CPU to see what comes back (all CPS do that, maker, model, speed, cores, even DIE revison levels.)
go to HP.com and put in your full tag number
and look it up, easy model PC comes is vast different sub models.
mine has over 10 processors, as an options I-5 up.
Even a DV5 has 50 or more sub models not counting the US mark in the end for USA.
facts. HP has 1000s of lap tops, and DT.
"I cant change values", my guess is you want to change, the BIOS settings That HP blocks so you dont burn up your parents CPU?
that?
now lets address slow
1: virus infected
2: :not upgrading to SSD drive, vastly slow if not upgraded !!
most LT etc are all slow, back before SSD.
all are. like that. what does yours have, scan that too, easy
SOURCE: I need help getting dvd+rw drive operating
hi
go to nearer computer sales and support centre purchase a DVD R/W and if u have CD drive dis connect power cable and data cable then remove screws from cd drive then remove it fromyour cpu cabinate in same place insert your DVD R/W fix all screws,data cable and power cable.then connect all the data/power in backside of cpu if you r removed before otherwise again check all the cables and power on your cpu/moniter.after booting sucessfully your computer insert your nero cd which is given with your DVD R/W,cd automatically open then setup it one by one by soing instructions.after setup complete your DVD R/W is ready to read write CD/DVD.
thanks
SOURCE: need a new processor
According to Compaq's web site, it takes a Socket 939 and the following processors:
Be sure that if/when you buy a CPU it is not Socket AM2, which is more common. You want Socket 939.
SOURCE: I have AMD Athlon 64 Processor 3700+ not reading at 2.40 GHz
Try going to Control Panel -> Power Options and changing the Power Scheme to Always On.
SOURCE: My pc Compaq Presario (S 3010 IL) AMD athlon
ether shop for a new motherboard or buy a new computer
SOURCE: Can i make a dual core run like a quad core, or add cores with out changing mother board?
You may be able to install a quad core processor on your motherboard, will need the model to check.
You can't make new cores out of nothing though.
Testimonial: "Answered half my question quickly now i just need to know if I can install a quad core processor in my motherboard. Hopefully I can do my part to help him let me know. "
Hi wkp22063, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
