Question about Hitachi 53UDX10B 53" Rear Projection Television
Help fix tv
I have blue, green and red on the top left and the lower right can i fix this myself or is it not fixable at all?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Solution$$$$$$$$
Posted on Jun 11, 2008
Philips 43pp92 blue will not converge
STK392-120 is convergence correction amplifier.. the problem is the convergence circuit... try to check the small Valuie electrolytic capacitors or High value resistors! maybe the said parts is in change Value... used a ohmmeter tester to find the chenge value parts!.
Nov 05, 2007 | Philips 43PP9202 43" Rear Projection...
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Bowed flickering green screen, black on bottom
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 25, 2009 | JVC AV-48WP30 48" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
Sep 24, 2008 | Panasonic PT-47WX53 47" Rear Projection...
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Televison & Video
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Light blinks 8 times
Best Solution by Guest worked!!! Great job and Thank you!
Nov 14, 2006 | Sony KP-51HW40 51" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
