Question about Onkyo TX-NR905 Receiver
Remote codes The instruction book says "Look up the component's remote control code in the separate Remote Control Codes list. It wasn't in the box. Where do I get one? Mike@itzin.com
  • 1,512 Answers
Hi mikeitzin
They are probably referring to any other universal remotes that you may wish to use. Do you have any other remotes that you use, I can find a code for you to match your system. Even some cable have inbuilt codes to drive audio equipment. Makes sense in this day and age.
If this is not a good solution to your problem, then dont rate it yet. Just comment back to this post and we shall investigate further and resolve your problem.:).
regards
robotek
Posted on Jun 13, 2008
Lost instruction book that came with ikonvert box
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electro-medical.blogspot.com/
Nov 28, 2016 | Televison & Video
How to program ONN (code?) urc with Motorola sat box
If you want the Motorola remote to control the TV or another device, then you should be looking at the instructions for the Motorola satellite box. You'll find a list of codes in the back of the book for the TV brands it supports.
If the code for your particular TV or other device isn't listed then there's a way to use the remote to search its entire code base. This can sometimes provide the answer where a certain TV chassis is sold under several different brands.
The Motorola DRC800 universal remote instructions can be viewed here
Motorola DRC800 User Manual
Sep 21, 2014 | Televison & Video
Can't find book for my Visco Codes, need codes to program into remote control.
I wasn't sure of your model, but the manufacturers pretty much keep the same codes from model to model. I found a free downloadable Visco instruction book and the remote codes start on page 42. I'm not sure if it is what you are looking for, but hope it helps.
http://content.etilize.com/user-manual/1010558313.pdf
Aug 11, 2011 | Televison & Video
I lost the papers that tells me how to set it up sony rm-v210 remote control
Here ya go. Heres some brief instructions and a link to sony for the codes and full instructions
Follow these steps to program the remote control.
  1. Turn on the component to be programmed.
  2. On the remote control, press and hold the SET button until the SET indicator lights up.
  3. Press the appropriate component select button for the component being set up.
  4. Using the number pad, enter the component's manufacturer code.
  5. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  6. Press the ENTER button.
  7. Point the remote control at the component and press the POWER button.
NOTES:
  • If none of the codes listed for the manufacturer work, it may be necessary to try codes listed for other manufacturers or perform a search for the correct code. Consult the Operating Instructions provided with the remote control for steps on searching for the correct code.
  • If a new code number is entered, the code number previously entered will be erased.
  • When the batteries are replaced, the programmed codes may be erased. It may be necessary to reprogram the remote after replacing the batteries.
  • The operation of a combination deck of any kind is not guaranteed.
  • Some product functions may not be able to be controlled by the remote control. Use the remote control provided with the component.
  • In some rare cases, you may not be able to operate your non-Sony equipment with the supplied remote control. This is because your equipment may use a code that is not provided with this remote control. In this case, please use the equipment's own remote control.
  • If programming fails, it may be necessary to reset the remote control. To reset the remote control, remove the batteries and press each button on the remote control twice.
go here for more information http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMV210
Oct 17, 2010 | Sony RMV210 Remote Control
I need the code book
You may not need the actual code book. You can manually "search" the "library" of codes stored in the remote by following these instructions:
1. Manually turn on the TV
2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality.
(from Answers.com) I hope this helps! Der Strom
Sep 27, 2010 | RCA RCR311B Remote Control
WHATS THE CODE FOR RCA TV ..I HAVE A ONE FOR ALL UNIVERSAL REMOTE NEED THE CODES TO PROGRAM MY RCA TV
You received a list of ALL Codes with your universal.
I got this off the internet. But I do not know what type of universal you bought. You didn't mention it.
Good Luck.
Here is the link if you need it. :0)
http://www.google.com/search?q=universal+code+for+rca+tv&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_en
rca
Nov 07, 2009 | Universal Remote Control P000203220-1...
How to code TV into Yamaha RAV290 remote
You have to assign the tv code to one of the components such as AV1 or Audio 1. If you have to separate the audio from the video channels then you need to go to the yamaha website and look at the firmware update manual from august 2009. It tells exactly how to do this.
Jun 20, 2009 | Yamaha RAV-300 Remote Control
I need code for my Tv
try one of these codes 003, 013, 012, 030, 046, 050, 051, 049 here are some instructions
  2. On the remote control, press and hold the SET button.
  3. While holding the SET button, press and release the POWER button
  4. Release the SET button.
  5. Press the appropriate component button for the component being set up.
  6. Using the number pad, enter the component's manufacturer code. NOTE: If more than one code number is listed for the manufacturer, repeat the procedure, entering one code at a time until you find one that works.
  7. Press the ENT button.
  8. Point the remote control at the component.
  9. Press the POWER button to verify operation.
NOTES:
here is a link for your remote controller http://esupport.sony.com/perl/model-remote.pl?mdl=RMV302#instr
Feb 18, 2009 | Sony RM-V302 Remote Control
Proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Feb 17, 2009 | Proscan 32LA30Q Television
Codes
try the following codes until one of them work:
002, 003, 004, 005, 006, 007, 008, 044, 045, 046, 053
  2. On the remote control, press the SET button.
  3. Press the appropriate component button for the component being set up.
  6. Press the ENT button.
  7. Point the remote control at the component.
  8. Press the POWER button to verify operation.
NOTES:
Nov 23, 2008 | Sony RM-V310 Remote Control
Onkyo TX-NR905 Receiver Logo
250 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
