We just replaceed the bulb in our projector and when we finishes the colors were all screwy.....every thing has a greenish or pinkish tinge and the blues all look a little green
First of all, make sure that you installed a lamp of the correct specifications. Also make sure that the lamp is seated properly and the contacts are clean.
Next, try a hard reset: Unplug the projector from the AC supply and
other devices for about 10 minutes. Then, connect to external equipment
and AC power before switching on. See if this helps and let me know...
It could also be that the input source which is connected to the projector may not be adjusted correctly, or the connection between input device and projector is faulty.
Please download the user manual from here and see pages 58 and 59 for proper procedure to replace the lamp. Also make sure you do the Lamp Time Reset to "0" as outlined in page 59:
http://www.projectorcentral.com/pdf/proj...
For further support, you will have to contact Panasonic tech support at 1-888-View-PTV(843-9788)
or send e-mail to : [email protected]
or go online at www.panasonic.com
Hope that helps! Should you have any further queries, please post back and I will try to assist you further as best I can.
If you found my solutions helpful in any way, kindly take a moment to "Accept" my solution. Thanks in advance.
Did you try to correct the setting..?
