Question about Toshiba 40H80 40" Rear Projection Television
Toshiba 40PW03B Tv has a fault where as when you turn it on it gives 3 green LED blinks followed by 29 green LED blinks then just blinks continuously. What diagnostic code is this and what does it identify as being the problem? Does anyone have a Service manual please. These are the symptoms after finding that a T (time lapse) 4amp 250V fuse had blown and a diode on the cct protection ring had blown/broke off from the stem so the fuse was replaced and the diode stem re-soldered. I do intend on replacing the diode as this could be suspect! Any help would be greatly appreciated, thank-you. Please advise if any further information/details or inspection of the boards is needed.
  • Rob 3 Jun 12, 2008
    The Diode (1N4148) is on the protection circuit and has now been replaced by a new one but the above symptoms still persist!
    Would really like a list of error codes even if for another Toshiba rear projection TV.
  • Rob 3 Jun 16, 2008
    Having now removed 6 x 1.8 ohm 2W +/-5% resistors on the V and H ccts for each of the RGB guns I do get a picture for at least a brief few seconds before the Protection Cct shuts down the TV, all three colours are showing though they are out of sync (not aligned) as one would expect.
    When tested the resistors are all giving a reading of 2.3 ohms, is this within the tolerance or should they be replaced? Not so easy to come by in the UK, if at all as I am still trying to find a source.
    Under these conditions the fault code is 2 green LED blinks followed by 30 green LED blinks.
SOURCE: toshiba 40pw03b stuck on standby
the red light comes on and off tv dont work
Posted on Aug 01, 2008
SOURCE: Toshiba 57H81 Flashing Red Power Light, Blown Fused F850+F852
Solved by resoldering some solder joints!!!!!!!
Toshiba Model 57H81 Rear Projection TV - Purchased 11-09-2001
Problem: Toshiba 57H81 Flashing Red Power Light, No Picture/Sound, Blown Fuses F850 + F852
Symptoms January, 2009:
  • Upon turning on set I got flashing red power light and nothing else.
  • Removing plug for one minute and plugging in results in:
    • Audible click, steady red power light for 2 seconds then slow flashing red light
    • Pushing power button results in steady red for about 2 seconds then slow flashing red light, no other set activity
  • Removing power cord for several hours and plugging back in made no change
    • Audible click, steady red for about 2 seconds then slow flashing red light
  • Possible related note: Over past several months occasionally the entire screen would flicker momentarily and at other times be problem free for weeks.
  • Fuses F850 and F852 found blown
Repairs Made:
  • PD0074 DEF/CON Power Board
    • There are two main power supply capacitors in this set. They are C-809 and C-810. One their negative lead on the printed circuit board re-soldered leads and nearby contacts. I’m told that because the factory left out a printed circuit board eyelet, the connection will come loose over time. When I called Toshiba customer service they said there was a known solder joint problem causing blinking red light.
    • Replaced blown fuses F850 and F852.
      • I actually installed a fuse panel on the inside of the cabinet and routed the fuse connections here instead of ordering the special fuses and replacing them on the circuit board.
      • Had to use a 5 Amp SLO-BLOW for F850. Fast blow does not survive power up. Get the red blinking light.
      • Used a fast blow 2 Amp for F852.
  • PD0073 SIGNAL Board
    • Re-soldered Q751 + Q752 STK392-110 Convergence Amps
    • Re-soldered adjacent pads that looks suspicious
Total Cost to Repair about $10
  • Twelve hours of my time over three days to research issue, disassemble set, make repairs, add fuse panel.
  • Already owned Service Manual and Circuit diagrams from a different 2004 repair.
  • Less than ten dollars at Radio Shack for fuses and fuse panel. Already had wires, etc.
  • Some solder. Already owned de-soldering tools, etc.
  • Visited both local authorized Toshiba factory service repair facilities. One said repair would have to include replacing Q751 + Q752 STK392-110 Convergence Amps with ST392-180, and realigning set for a total of $500+ and it would be more if they had to order a power board. NO THANK YOU! Other shop said $65 for site visit and $30 to make an estimate that could be applied to repair.
Posted on Jan 05, 2009
  • 22 Answers
SOURCE: F850 fuse blown in Toshiba 50HX81. What does that protect ? Replacement ?
hmmmmm can you replace the fuse
Posted on Mar 11, 2009
Angel Petter
  • 114 Answers
SOURCE: tv turns on and off 3 times before picture appears
have you Reset your Lamp?
every time that you change the lamp you need to reset and start a new count..
Posted on Mar 24, 2010
  • 8457 Answers
SOURCE: Toshiba 50H81 - Red light blinking after I
Problems was convergence problems,before u replaced those 2 STK convergence ICS?Check and replaced those resistors on the convergence board too?
Posted on Sep 18, 2010
Hello, I have Toshiba TV Model #47L7500U. When I turn it on the TOSHIBA (red) logo comes on for a several seconds, then screen goes black. Green LED on front continually flashes green. No pic or sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 26, 2017 | Toshiba Televison & Video
TROUBLE SHOOT LC-60E78UN TV
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Oct 30, 2016 | Sharp Televison & Video
Toshiba hdtv 37rv530u fails flashlight test. Green light on main board lights up inverter board flashes a blue led twice. Can the led screen itself go bad ? Or do I have multiple boards bad?
Apr 30, 2016 | Toshiba 37RV530U LCD TV
Green light blinks 3 times
Hitachi p50s601 led blinks 3 times - YouTube
? 2:22
www.youtube.com/watch?v=xM6bpKK0LG0
Jun 28, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click ... flash, but when I remove both boards the TV just runs agreen solid led as if it .... It would show a static then go right back in the 3 blinking blue lights.
Apple TV: About the status light - Apple Support
https://support.apple.com/en-us/HT200154
Apple Inc.Apr 29, 2015 - The Apple TV status light (LED) glows steadily, flashes, or turns off. ...Flashes three times, Rejecting a command from the remote (you've ...
Oct 19, 2015 | Televison & Video
Sony Bravia not turn on! blinking led....
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 15, 2013 | Sony BRAVIA KLV-S32A10 32" HDTV-Ready LCD...
My sony trinitron kV ES 34M90 GIVES 6 ERROR BLINK CODES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. To get more details, http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Sony Televison & Video
I have sony 29'' crt tv . model no KV-DZM61 .when the tv statrs on it shows green led,and after few second the led glows red and it blinked for 2 times .then the tv goes in stand by mode
2 blinks means - over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
Jun 23, 2011 | Sony KV-XR29M61 TV
Can you give me the codes for a Toshiba television set using One for all universal remote URC-3021BG1
To control a Toshiba TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0154, 0156, 0060, 1356, 1656, 1704, 0650
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
Hope that helps.
Oct 26, 2009 | One For All URC-3021 Remote Control
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
Toshiba 40pw03b stuck on standby
Jul 28, 2008 | Toshiba 40H80 40" Rear Projection...
Toshiba 40H80 40" Rear Projection Television Logo
99 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
