Question about Saeco VIA Venezia
Steam It heats up and steam comes out, but not as much as normal, When I open the steam valve it comes out heavier right when it opens, and the more I open it the steam slows down.
    Scholar:
  • 65 Answers
The Steam is regulated by 2 thermostas.One for the maximum pressure and one for the minimum pression.It is normal the steam it`s so strong on the beginning and slow when is time for the other thermostat to tell the machine to heat the water again.Saeco is always been like that and i don`t really like the fact the range between this 2 thermostat is pretty far away each other on temp range.It`s saeco...and if you want to change that you need a min thermostat re arm the heater ealy compare the original one.An easy example can be this : min 105 degree ....max 135 deg.
This mean the heater will work ana max of 135 and a minimum of 105.This is just an example.You need to have a schematic to find out the real working range of the thermostat
Posted on Jun 21, 2008
  • 40 Answers
Have you descaled your machine? If so, it could be that your steam valve may need to be replaced.
Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
I turn the ECM Giotto on, the light comes on but the pump does not activate and no heat. 2 hours later it all works fine.
Try this open the steam valve when you turn the machine on, leave the valve open until it starts to hiss with steam, then turn off valve. If that works then the vent valve is sticking and needs to be replaced.
Oct 12, 2011 | ECM Giotto Espresso Machine
Fissler Pressure cooker has steam coming out from the Utimax valve, is this normal?
Hi. Some steam is ok. But when it is running it should be sealed up. The little rocker should be doing it's thing too. Good luck.
Jul 25, 2011 | Microwave Ovens
We've had the Rancilio Audrey now for a year and still not have had a perfect cappucino. 1. Milk. We use 3.5 dairy milk, cold before going under spout. 2. What is the middle (steam) button used for? ...
  1. That is the right milk. Use a thermometer with the milk.
  2. The middle button is used for steam. It engages the high themostat for steam.
    1. Slightly open the steam valve
    2. Turn on the middle button
    3. Keep the end of the steam wand slightly above the milk surface (0.5 mm) so the steam incorporates air into the milk. (Takes practice)
    4. Open the steam valve as the boiler heats up. (Takes practice)
    5. When the milk get to 74 C (165 F) immerse the steam wand into the milk and heat to 82 C (185 F)
    6. Turn off the middle button and shut the valve.
  3. For 90 ml of coffee, use 14 gram of ground coffee. The coffee scoop that came with the machine holds 7 grams of ground coffee as it comes out of a grinder (not packed). Tamp the coffee after it is in the sieve.
Jan 01, 2011 | Rancilio Audrey
Red boiler light will not go on. The boiler does heat up.
Open the steam valve when you turn the machine on that will vent out the boiler, keep it open until it starts to hiss slightly and produce small steam bubbles, then close and machine should heat to temp. If that solves your problem then the vent valve needs to be replaced, until then you can turn using the steam valve open trick.
May 31, 2010 | Isomac Tea Espresso Machine
My 5 year old Giotto has stopped working
The vent valve on the machine is stuck in the open position. Turn on the machine and open the steam wand until you hear a hiss or see small water bubbles from nozzle, let it steam out a little more then close wand, that should allow the machine to heat up correctly, then order a new vent valve for the machine.
May 03, 2010 | ECM Giotto Espresso Machine
My 2 group astoria over steams from top of boiler.it warms up then in about half hr steam shoots out at the preasure valve doicky do i need a new one of those thanks greg
The pressure releive valve is pre-factory set to open if the pressure in boiler reach between 1.6 to 1.8 bars.
So either you have the presure switch (presostat) not working normal which supose to switch off the electrical element at 1.2 to 1.3 bars.
So look at the presure gauge at which presure the presure releive valve open and releive the steam out from boiler if it shown more than 1.5 bar the you need to check the presure switch since it does not switch off the heating element.
If the presure releive valve open below 1.5 bar then you need to replace the releive valve.
Good Luck
Mar 23, 2010 | Astoria Argenta SAE-2 Espresso Machine
At the end of initial pressure-up after first turning my Epoca on in the morning, the pressure goes past 'normal' until it blows the escape valve. What is wrong? Thanks. Matt
The vent valve is stuck in the open position, leave the steam wand open, while the machine is heating until you hear it hissing, then close steam wand and machine should heat up properly. Replace the vent valve as soon as possible.
Mar 01, 2010 | Rancilio Epoca ST-1 Espresso Machine
How do i use the pressure cooker? After adding water and beans, I let it come to boil and the steam noise is steady....then I turn down the heat? At the end I let out the steam manually, turn off and open...
Add the water and beans. Put the lid on the cooker and tighten down. Turn on the heat and let the steam make a full plume before closing the valve. Lower the temperature to medium. Watch the gauge and when it reaches the correct pressure keep adjusting the heat to maintain the pressure for however many minutes the beans need to cook. When the time is up turn off the heat and let the cooker cool for a while. Ten minutes or so. Then slowly open the pressure valve when the pressure has reduced to a low level. If the pressure is still to high when you open the valve the water will be pulled out of the beans and the jars will only be half full of liquid. Once the pressure is down to zero, open the lid carefully because the jars are still hot and break easily. As the jars cool you will hear them pop. This means that they are sealed. Good luck.
Jun 15, 2009 | Kitchen Appliances - Others
No steam coming out of heating nozzle for Wega
Remove the nozzle on the end of the steam wand, them open valve to see if the steam wand works, if yes use a paper clip to clear holes on nozzle, if no remove steam wand where it is connected to the valve then open wand(steam will be spraying be careful). If you have steam there then clean wand and nozzle.
Dec 16, 2008 | Wega Mininova EPU Espresso Machine
Steam sauna (mr Steam ms400tc1). Unit fills up then allows water to exit via steam head without heating up to steam. Unit should stop water entering heating tank when full, heat up to steam, then allow...
If that unit has a steam valve I'd suggest checking it to ensure it's not stuck open. If it is, the steamer will not build pressure also. Should be a gauge for tank pressure that will show if it has built up pressure. If the valve is stuck open, it may certainly just dump water instead of steam. It's possible the water level sensors are allowing too much water into the tank, and as a safety it dumps. I've changed steam valves quite often due to the amount of heat they have to deal with.
Sep 16, 2017 | Heating & Cooling
Saeco VIA Venezia Logo
136 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
