Question about PfaFF Creative 7570
Pfaff 7570 creative card
When turning my Pfaff on with the creative card of designs, and after hoping to choose a design from the card, all I saw on the screen were scribbles. I lost all the designs on the card. I then tried to format the card and couldn't do that either. Is there something I can do myself to clear all the scribbles I see, when turning on my machine also? Thank you in advance. Eva T.
  • Anonymous Mar 21, 2014
    I have 3d suite installed on my computer for my pfaff creative 2124. To transfer designs i use a smart card station. I have recently installed it on a new computer but the card station is not being recognised due to no drivers being installed.
    I have tried to download but no sucess yet.
Turn on computer. and open disk to delete patterns on purple disk that goes into the sewing machine
good luck
Posted on Apr 22, 2010
  • 41 Answers
Hi Eva,
You should be able to clear the card by holding down the card key as you turn on the machine. You should then be able to reformat.
Posted on Jun 14, 2008
  • Kim Fillmore
    Kim Fillmore Jun 20, 2008
    Hi Eva,
    In thinking this through a bit more ... (it's been awhile but I used to troubleshoot just these kinds of things for Pfaff) if you do a second clear right after the first one (press & hold the Card button as you turn machine on) it may do the trick. When you go through this process, you should get a screen that asks if you're sure you want to clear the card - select Yes - I believe you'll then get a screen that asks you to rename the card (anything you want or just a number). If I recall correctly a single clear didn't always get rid of the scribbles but the second one was generally successful.
    If this still doesn't work... some of the blank cards had a replaceable battery - and the battery may be getting weak. Look at the narrow end of the card that DOES NOT go into the machine. If you see 2 tiny buttons, this is an indication that you have a card with a battery. One of the buttons is the Write Protect, the other opens a door that houses the battery... standard watch-style battery. If you only have one switch on the end, your card does not have a replaceable battery and may just be reaching the end of it's life.
    Hope this helps,
What format does the Pfaff 7570 use for embroidery?
The format that is used by the 7570 and the 7560 is *.pcs or *.dst. Either one will work provided that the designs are within the confines of the hoop. The largest size design that would be embroidered by this machine would be 115 x 120 MM.
Jan 03, 2013 | PfaFF Creative 7570
Where to buy another creative blank pfaff 7570 card
try contacting pfaff customer & ask them if a pfaff dealer would carry them
also try
May 02, 2012 | PfaFF Creative 7570
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
Does Pfaff have any Disney fantasy cards for the 7570 embroidery machine
no brother has exclusive rights to disney designs look for brother 780d embroidery only machine as cheepest option
Mar 19, 2011 | PfaFF Creative 7570
Do you have orcan you find a creative card for pfaff 7570
If you are looking for blanks, I could not find any.
You may have to go this route - always check with the vendor before purchasing to be double sure this will work with your model Pfaff.
If you are looking for design cards - there are several listed on Ebay.
Mar 04, 2010 | PfaFF Creative 7570
Connect PfaFF Creative 7570 to a PC
The software you need to connect the Pfaff 7570 to the PC and to create your designs is called PC-Designer version 2.2 from Pfaff. You may be able to find a used copy. The software should come with a dongle (special cable) for connecting the machine to the PC. Make sure you have this piece because it will not work with an ordinary cable. Depending on what type of port you have on the PC to connect to, you may also need an adapter since the dongle has an old style connector on the end going to the PC. If you are going to create your own designs, you will also need a storage card which inserts into the machine that you send the designs to. Pfaff makes one, called the creative card. I have also used a generic card meant for the pfaff; the generic card is less expensive and has a greater capacity. You can find many designs online either free or for sale to send from PC to Pfaff as well.
Nov 27, 2009 | PfaFF Creative 7570
Cd embroidery designs
You must use the card. If it were a newer model with an actual usb connection you could.
Apr 05, 2009 | PfaFF Creative 7570
Pfaff 7570 program
I have somewhere that installation diskette (with the old SW version). If I'm not mistaken it was not included with the sewing machine but sold separately with the embrodery arm that we bought together with it some 10 years ago. Email me to if you need more help.
Jan 08, 2009 | PfaFF Creative 7570
Sewing Machines Logo
490 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
