AC not cooling
My AC fan is working,but it is not cooling. I am not expeing major defect! It is only 4 years old unit.
    Genius:
  • 1,036 Answers
It is possible that either the AC pump is not working at all, or that the refrigerant has leaked completely.
Both can be tested by an engineer, who will give you a quote on repairs needed.
Hope this helps.
Posted on Jun 11, 2008
Why cools the ac only 1 hour full power and never reaches the set-point temperature ?
check that all the doors and windows are closed as ac units do not work well when trying to cool the world
is the ac unit too small for the room size
I suspect that because it is working the problem is outside the ac control
is the inside fan working and blowing out cold air
May 22, 2016 | Heating & Cooling
I have a Goodman GPH1324H21A the fan comes on and the AC kicks on for a couple of minutes then shuts down what's wrong with it?
if it's 4 years old it doesn't have r22. Are BOTH fans running when ac shuts down? Inside unit or outside unit shuts down?
Jan 08, 2018 | Goodman GPH1324H21A WallWindow Air...
I have ac unit which is only a year old. I just recently installed it, the fan is working but the ac is not cooling when set on cool. I cleaned the filter already, not sure what else i can do to fix this...
if you can here the compressor kick on (the fan will also be running) if the compressor is running and not cooling you could have a leak and it needs fixed and recharged
May 31, 2011 | Kenmore Heating & Cooling
I have an old (35 years) Kelvinator No Frost 480 which seems to be functioning, but not cooling the bottom half of the fridge as it should. The cooling elements seem to freezing up. The fan and compressor...
gfhgfhgfh
fghf
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | Kelvinator Refrigerators
Have 2 year old Frigidaire FAH105N1T Air Conditioner. Fan stopped working on fan or cool. Serviced twice and they said fan needed to be oiled. Worked 3 weeks then they said it needed fan motor. Bought new...
it possible to replace the defective as follow:
1- take out the unit
2- remove the top cover
3- try to take out the wires from there connections and note each color to witch connection
4- loose bolt of indoor blower to the shaft
5- open the bolt of the condenser fan to the other end of motor shaft and take out the fan
6- open the fixation nuts or bolts of the motor then slide it outside.
7 replace as take care about witch side of shaft is for blower or fan.
Sep 06, 2009 | Heating & Cooling
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
LG AC compressor problem
Compressor may be locking up. Run capacitor may be weak or loose wire. Sounds like major voltage drop off as unit head pressure increases.
Jun 28, 2009 | LG Heat cool Window Air Conditioner
Goodman CKL60-1 Condenser Fan Runs OK, then stops
check connections tightness or if you just change the connector will solve the problem that is if the motor has not burn out yet
May 28, 2009 | Goodman CKL60AR60 Air Conditioner
Bad bearings on the motor or check the fan rotations . Air should always blow out the top and **** in through the sides or coils.!... Thank-you-very-much!
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
AC shutting down, not cooling
your landlord needs a service tech !sounds like you have a few issues.possibilities include control issue,plugged evap coil,plugged blower wheel,possible freon issue.This one's a little too big to handle here.
Jul 26, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
132 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
