Question about Sony KP-46WT510 46" Rear Projection HDTV
Convergence ic my television has a red shadow image the appears to float in an arc toward the bottom of the screen. how do i fix this?
    Sergeant:
    Champion:
  • 250 Answers
You will need to replace your convergence IC's. They are located on the D Board, left side board that is mounted flat on the bottom. They are on the two large heat sinks you can see at the back of the tv. Get the part numbers off those and order some new ones along with thermal grease. You'll need a good desoldering gun or braid and a good solding pencil. Buy thin soldering not the thick stuff. Radio Shack is a good place to get irons and solder for the job.
Posted on Jul 07, 2008
Blue shadows and a yellow and blue arc acroos the bottom of the screen
Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Pioneer SD-582HD5 58" Rear Projection...
I have red and green shadow on top and bottom of the screen.
Ur Convergence board is dead or deffective with the IC chip.
Aug 17, 2009 | Akai PTH5498 54" Rear Projection...
Picture blury and stretched
You have bad convergence ICs, requires disassembly and soldering to replace, quan (2) stk392-120 can use 150s or stk394-160 also.
they are located on the SSM CBA facing back left side, many delicate cables , torx 10 screws also look for any discolored 6.8ohm resistors near the ICs, usually (2) burnt resistors. most shops charge around $300 for the job done in house. Also will need to check that the yoke aren't loose and tilted (philips had black tape on some). and you may need a fluid change by now on the Blue and green CRTs (a professional job for sure). good luck !
Eric
Jul 31, 2009 | Philips 60PP9202 60" Rear Projection...
Red, Green, Blue curve upwards and cast shadows
that sounds like a typical Convergence IC problem..
http://i.ehow.com/images/GlobalPhoto/Articles/4575598/ConvergenceICs_Full.jpg
this is a picture of what typical convergence ics look like
Mar 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Distorted Color and geometry of Picture
Sounds like a convergence IC problem, you will need to replace them'
Heres a quide
see the before and after pictures to verify your problem
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 15, 2008 | Televison & Video
Red shadows around images on screen, setting convergence doesn't help
HELLO. it not in adjusting the len's it's in the convergance board. the IC'S ON THE BOARD NEED TO BE REPLACED."GOOD LUCK"
Jul 25, 2008 | Akai PTH5498 54" Rear Projection...
Everything on the screen has a blue shadow
need to change both convergence ICs STK392-560. you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | Sony KP-46WT500 46" Rear Projection...
Help
your having convergence circuit problems, you`ll need to change the convergence IC`s and any burnt resistors in the convergence circuit, if you have questions e-mail me back, good luck, BMW Rider
Jan 03, 2008 | Toshiba 53HX71 53" Rear Projection...
Blue arc
There are 2 large convergence IC's and the one that handles Blue Vertical (BV) has burned out and needs to be replaced. This is by far the most common failure in those projection sets. It is a good idea to go ahead and replace both STK392-110 IC's with the newer improved STK392-150's. If you have never replaced convergence IC's and realigned convergence circuits then have a qualified tech handle it for you.
Aug 05, 2007 | Toshiba 53H71 53 in. Rear Projection...
Blue and red shadows on screen
This sounds like one of the convergence IC's has cracked loose or burned out, and should be replaced and realigned by someone with experience.
Jun 26, 2007 | Hitachi 50UX57B 50" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
51 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
