Received from Danby customer support:
"The error code of E3 tells us that the unit is not getting the proper water temperature to continue thru the entire cycle. Before starting the dishwasher and attaching the quick connect assembly to the faucet, please make sure that the water from the faucet is warm to the touch; you can then attach the quick connect assembly with hose to the faucet and start the unit. If the water temperature does not reach 120 degrees F the dishwasher will not be able to run thru the entire cycle properly. If this is being done and the same code comes up, we will need a service tech in you area to diagnose the problem for us. For a warranty servicer in your area you can reach us at 800-263-2629 Mon-Thu 8:30-5 or Fri 8:30-4 EST."
Same thing!
I had that problem too, I just took it back and got another one that starts up ok... still has other problems though : P
I have the same problem...
I have the same problem as well. I wish I knew what "E3" means. There should be a section in the manual that interprets the error codes. My dishwasher will go through the beginning of the wash, maybe halfway, then stop, drain water, and beep "E3".
