Question about Lanzar VIBE266 Car Audio Amplifier
Protection light grief
Its a refurbished vibe 276 , just got it in the mail today. I hooked everything up, im positive that everything is wired correctly. I set the gains to about 3/4 of the max. the amp plays just fine at low volume but when i turn it up i will only run for a few seconds to a minute before it goes into protect mode???
The amp itself takes 2 x 25 amp fuses and i am running a 100 amp fuse from the battery, Is the amp getting to much power?
please help..... thank you
  • Lanzar Master
  • 637 Answers
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Vibe is mediocre. Time to invest in an old school Lanzar Opti Drive amp. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection light grief - protection-light-grief-shonxoarcym4awy4zl1imx4o-2-0.jpg
Posted on Dec 19, 2014
  • 109 Answers
Sounds like you either got ripped off or you're not using a large enough power/ground cable, or you have bad connection(s) somewhere; bad grounding location, etc.
Posted on Jun 19, 2008
I have a 600watt vibe amp all wires are connected correctly but power light comes on and then goes straight off and repeats this constantly whats wrong??
most amp have a protection feature sounds like somthing is hooked up wrong or u have a short to ground id recheck using a multi meter if all test r good then ur amp needs to be serviced.
Sep 17, 2009 | Lanzar - Vibe: 2 Channel 600W Vibe Series...
I have a lanzar vibe 255 can u help me?
Double check your connections. Use volt meter to co firm proper voltage. A test light can still light up with low vol
Jun 28, 2009 | Lanzar Vibe 255 Car Audio Amplifier
Protection mode on my amp
Jun 15, 2009 | Pioneer GM-7200M Car Audio Amplifier
Protection light
take the amp out and hookit up to the car battery and let it charge then unplug it do this a couple of times then rehook it to the cars audio system it sounds like your amp may be locked..
also check your speaker wires from amp to speaker box then from the back of the box to the speaker inside the box you may have a short..
thats where i would start.. hope this helps
Dec 19, 2008 | Car Audio & Video
First, rule out problems with the wiring to the speakers. Disconnect the speaker wires to the amp. Get a AAA battery. Hold one of the wires to the negative side of the battery and lightly grace the other wire across the positive side. You should be able to hear something like pops and scratches coming from the speakers. Do this for all the speaker wires and wire-tie each pair.
Nov 15, 2008 | Phoenix Gold Car Audio & Video
Protect at high volume
No such thing as too much power unless you have a faulty alternator/voltage regulator.
The hundred amp fuse at the battery is better than none but I would replace it with a 50 Amp, that fuse is really only protecting the power wire from grounding out and burning.
The gains are irrelevant, all they do is attenuate the input.
Set them so you cant hear any amp hiss or noise on quiet passages of music or between tracks.
Make sure your not starving the amp for power. Start at the battery connections and work your way back to the amp, inspect all connections for corrosion and make sure they are tight.
Check the ground wire . It is just as important as the power wire!! Try to ground it as close to the amp as practical, scrape off the paint down to the metal use a oversize screw with a star lock washer and a ring terminal.
Make sure that your power wire and ground are at least 8 gauge.
Next on the list is your speakers and related wiring, check to make sure that your impedence is not too low for the amps rating. and that the wiring is correct and at least 16 gauge, 12 is better.
. You can check the speakers impedance with a Ohmmeter, it wont be exact but it should be close +/- .5 Ohm If you are bridging, make sure the speakers are wired in parallel + with+ and - with - .check the amps rating and bridging configuration, it's normally left positive, right negative, but check!
Having done all the above, and you still have a problem only two possibility's left, Defective speakers or the amp. Check with a qualified installer, buy him lunch, you'll get good advice forever.
I hope it helps. Regards Paul
Jun 11, 2008 | Lanzar VIBE266 Car Audio Amplifier
Lanzar Vibe 1200D protection light
You will need to show it to a service technician as it seems the output section has blown so it remains in protect mode. One reason (could be) that the input to the amp was high and may have been clipping for some time before the amp decided it could take it no more
Jan 14, 2008 | Lanzar Vibe 1200D Car Audio Amplifier
Protection Light Is Coming On
try redoing the wires you might have wires touching somewhere if that dont stop it try new RCA wires
Jan 08, 2008 | Lanzar Vibe 235 Car Audio Amplifier
Protection mode on Lanzar Vibe 241
Almost without exception, if the protection light comes on as soon as you power it up, the output transistors are defective. Any reputable repair shop that services car audio equipment should be able to repair it.
Oct 06, 2007 | Lanzar VIBE241 Car Audio Amplifier
Lanzar VIBE266 Car Audio Amplifier Logo
156 people viewed this question
Top Lanzar Car Audio & Video Experts
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
