Question about Sony Playstation 3 (PS3) Console
White lines, images on screen turn funny colors, audio humming
I need help on how to get rid of this and what is causing this problem
Hi :)
I had small white dots appear on the dashboard screen, like static... I am using an HDMI connection.
Make sure that your cables are connected correctly...
Try going to the display settings and selecting the automatic setup for HDMI, that worked for me, it looks pefect now..
my problem is that discs are not loading(but that's a different issue)..
It might work the same way if you're not using HDMI.. just select your connection again, or change connection settings and back again. But make sure that you select the correct settings if you want it to display correctly.
I hope that helps, good luck.
Posted on Jun 11, 2008
I have a TH-PX60U that has a black line going down the front of the screen. It goes from black, then back to regular color. The black line keeps coming back. How can I get rid of the black line??
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 08, 2015 | Televison & Video
TV burn in / fading effect?
TV has an image burn into it? Put the tv in white wash (all white screen) by going into your settings. By having it in an all white screen may help get rid of the burn image. Must have it on white wash for some hours until you can see that the image is disappearing.
Jul 16, 2014 | LG Televison & Video
The screen is green no color at all it makes aloud humming sound what is the problem we replaced the lamp last year
Do you have a cable box going to the TV and is this condition on all of the inputs or just one. Chances are you have standard video connection plugged into the component inputs.
If you have a (yellow/red/white) cable make sure you have it plugged into a connection on the tv that matches those colors because if you have a standard video (yellow) plugged into the Green then you will get a black and white picture.
If you are plugged into a component connection you will need a total of 5 RCA style wires. One will go from Green to Green, another from Blue to Blue, another from Red video to Red video, anther Red audio to Red audio and white audio to white audio.
The common mistakes made with this connection is the reversal of the RED video and RED audio which will cause the humming noise you spoke of as well.
Thanks,
Robert
Mar 01, 2011 | Hitachi 60V500 60" Rear Projection...
My viewsonic vx2025wm 20.1 lcdmonitorgoes green,sometimesyellow,then returns towhite screen
check your cable connection if the color changes.. as normally bad or lose display connection will cause this problem..
but if it turn to total white without any image.. then most probably the LCD monitor is faulty..
but there are some cases when your display card that is giving this funny problem.. if it get too hot.. check your PC display card whether the cooling fan is turning or jam.. this is the main cause the display card get overheat and give you funny display...
May 23, 2010 | HP Computers & Internet
Tv started to shut off here and there, then the
Hi,samsung has 3 major failures.The 1st one is the lamp, which averages 6000-8000 hrs 2-4 yrs.When it's about to go bad it shuts off and on or image won't come at all.You can find your part here:http://www.discount-merchant.com/SearchResults.asp?Search=BP9601472A Another problem that causes tv to shut off is the ballast,which is the board that powers the lamp.It makes clicking sounds and will cause pic to flicker.The other problem is the color wheel .The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Have a bless one!
Apr 12, 2010 | Samsung HL-S5086W 50" HDTV
Samsung HL-P5063W audio is fine, no picture. Initially made a loud buzzing sound, so we replaced the color wheel. No more buzzing sound, audio is fine, but screen is various shades of white. Left TV on for...
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 02, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Funny colours on screen?
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 01, 2010 | Televison & Video
Funny colores and shades on my Toshiba projection TV
the convergence tube is the faulty part in this case a new convergence tubes replacing is required.
Jan 30, 2009 | Toshiba 42H81 42" Rear Projection...
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony Playstation 3 (PS3) Console Logo
139 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
