Question about Amana Kitchen Ranges
My Caloric gas wall oven ModelRPW216 Serial # 4961421 needs a new ignitor. This is probably a 1980's model. Can I still buy this part?
    Master:
  • 638 Answers
Yes definitely you could get this part.
Posted on Jun 11, 2008
  • hemant somaiya
    hemant somaiya Jun 11, 2008
    give me your perfect location and your zipcode we can provide u the technician who can guide you properly. rate this solution fixya if it helps u anyway to encourage us to solve more and more problems. good luck.
  • hemant somaiya
    this link will help you to find the ignitor or any other part easily.
    http://www.appliancepartspros.com/partse....
    thank u for giving me a chance to help you. rate it fixya if this helps u.feel free for further assistance.
    Brigadier General:
  • 3,614 Answers
We will check...
My elderly neighbour is trying to light her Hygena Classi Oven built in when she turns the knob to the required number no gas is coming out to light it.
Hello Jean;
My name is Peter. I am a retired field service appliance technician.
There are several different components that may be at fault for this problem. The most probable is a bad gas ignitor. Your ignitor may either be broken or too weak to open the gas valve.
On built in wall ovens:
1.) Remove the oven door. Tilt it out to where is stays slightly open and lift straight up. When replacing the oven door make sure the hinges that the door mounts on are pulled slightly out to slide the door back on.
2.) Remove the cover on the bottom of the oven. You will see the gas burner and in the center of the back wall the gas ignitor.
3.) To replace the ignitor, you will have to remove the two plates below the ignitor.
Locate your oven model number. It is on a label either on the face of the oven after you open the door or on the side of the door.
Go into the internet and search; "Ignitor and your model number".
Make sure both your oven gas and electrical power are turned off before you do anything!
Mar 06, 2016 | Kitchen Ranges
Why won't the gas oven heat? The oven won't light and gas is not leaking when I turn the oven on.
does it have a pilot light or is it electronic ignitor . might need ignitor replaced
Jul 23, 2014 | Ovens
I have a caloric oven, prestige series. Don't know model. it is about 15 years old. last year the oven wouldn't heat and smelled gas. That was repaired. Now, oven ignitor comes on but oven...
The ignitor is bad again,if it (ignitor) comes on but no flame/heat its the ignotor again, what would make the ignotor go bad so fast (usually last 10-15 years) is a problem with the oven burner, so now BOTH the ignitor and burner would need to be replaced,if it is 15 years old the ignitor is readily avaliable but the burner may not be
Gene
Aug 04, 2011 | Ovens
I have a 31-year old Caloric gas wall oven (Model RWD216) that finally died. I am ready to install a new unit, which means taking out the old Caloric. My question is, how do I unhook the gas line from...
first turn the gas off at the meter/ a oven this old may not have a shut off in the back. then you can remove the oven safely/ the line in back will hook to 1/2in or 3/4 pipe stub. . if you have a shut off in the back turn it off and reconnect new range to it . and if not make shure you put one in .. mm
Nov 22, 2009 | Ovens
Looking for a Oven knob for the Caloric Presige
http://www.appliancepartspros.com/partsearch/
or
http://www.expertappliance.com/caloric-stove-parts.html
Oct 18, 2009 | Ovens
Frigidaire model number FGF356MXAWR, Serial #VF34511587 oven
it is probably the bake ignitor needs replaced. the only way to check it is with an amp meter. however, this is a part that does fail alot, and you can buy one for pretty cheap. it is located mounted on the bake burner by 2 screws. and it only involves splicing 2 wires, (the wire nuts you need should come with the new ignitor)
Jan 04, 2009 | Frigidaire FEB27S5A Electric Single Oven
Caloric oven does not completely light
i would replace the ignitor, although its glowing its not glowing strong enough to allow gas to release, simple repair, part numbr 31939701
Nov 22, 2008 | Kitchen Ranges
Kitchen Ranges Logo
123 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
