transfer case shift control module
Transfer Case Shift Control Module Replacement
Removal Procedure
Important: The transfer case shift control module (TCCM) is located under the drivers seat carpet. For removal purposes, access the TCCM from underneath the carpet.
Remove the drivers bucket seat or split bench seat. Refer to Front Seat Replacement - Bucket or Split Bench Seat Replacement.
Remove the left front sill plate. Refer to Front Side Door Sill Plate Replacement.
Remove the left hinge pillar. Refer to Body Hinge Pillar Trim Panel Replacement - Left Side.
Remove the left center pillar. Refer to Center Pillar Lower Trim Panel Replacement.
its your door stop,id do the junk yard thing first,try to get one new you get new pins and thats good.or myself,if your hady with tools you can use the passengers side to copy one cut it out drill it and pin it.
Hi, This is a generic problem in most of Dell Laptops ( mostly inspiron ). It is caused due to a fatal fault or breakage in the Hinge Assembly. You need a new Hinge Assembly. Is it splitting more on decreasing the angle of the monitor. If yes, Hinge assembly is the only culprit. If you are under Warrenty then Dell will be liable for it and replace it free. If not under Warrenty, I approx. costs 300$. Thank you Sir, Have a nice day.
I have a HP Pavilion zv6000 laptop too, and I have the same problem. A year ago, the screen was getting loose and finally it just broke. Won't stand up. I've been propping it up against a wall for a year. I can see what is wrong: my laptop has gotten so hot that the back of the laptop where the hinges are has warped and ruined the hinges. Do you notice that? The split in the seem and the actual bend of the plastic? Anyway, the computer itself works perfectly. I was going to buy new hinges and replace them myself, but it was too much of a hassle, and I needed a new laptop anyway. The hinges are inexpensive. And the laptop isn't TOO difficult to take apart (search for the manual. it's easy to find). I took it apart with my Grandpa, and he's old, and I'm a girl. (okay, sexist, gender...ist.)
I actually received a new laptop as a gift. Luckily.
No solution, other than replacing hinges. I just wanted to let people know I too had the same problem.
