Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Printer claims black ink cartridge is empty, but it can't be.
my HP Officejet Pro L7580 will not let me print and claims I need to replace my black ink cartridge, however I have not yet printed with this so it cannot be empty. Has anyone else experienced this problem or am I simply doing something wrong?
Thank you in advance for help with this problem.
  • carolatk Jun 24, 2008
    trying to replace black ink cartridge for 1st time and it won't acknowledge that there the new one has ink in it. It keeps telling me to repalce the cartridge because it is empty.
  • Anonymous Mar 31, 2014
    yellow ink cartridge is full but it says its empty and needs to be replaced
    Scholar:
  • 94 Answers
Hi, one possible solution that we can provide on that issue is reseat the ink cartridge. If issue still present after reseating the ink cartridge we need to isolate it. Try replacing the ink cartridge with a new one. In some reason the chip on that ink cartridge might be damage thats why even there's iblack ink on that ink cartridge the printer still detected it as empty.
--->> Tirzo
Posted on Jun 11, 2008
    Scholar:
  • 130 Answers
Se if the tape, that comes with a new cartriage is of the cartriage if not try a new cartriage if the does not work your machine needs service
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Hello, I have an HP Officejet Pro L7580 All In One printer. Sat for 2 years. Barely used when purchased 3 yrs ago. Just hooked it up again. Replaced all ink cartridges...now prints are very pixelated and...
Try doing running it through it's aligment process.
It is also possible that the contacts where the ink cartridges mate up with the printer are corroded. Try using an eraser to clean the corrosion off the mating surface in the printer.
Jan 22, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
The black ink print is very very faint
Indicates that the printer is using only color ink to create a black color. Check printer settings to see if you can set it to use only black cartridge. Also try printing with only the black cartridge inside if the printer permits, this way you can be sure if the black print head is faulty.
Jul 28, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
I have an HP Officejet Pro 7580. When printing in
I think ur catridge must be empty plz fill ur catridge and then check
May 26, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Hp l7580
Hi, it sounds like a faulty ink cartridge. Try changing the black cartridge and see if this helps
Dec 16, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
Black Ink won't print
Try cleaning the printheads:
On the control panel press Setup>Select Tools>Select Clean Printhead
If that doesn't work, try manual cleaning the printhead contacts. This begins on page 147 of the User Guide.
L7580 User Guide
Nov 03, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Empty ink error message
Hi, its sad to say but the printer sounds that needed to be send to the nearest service center in your area. You already reseat & replace the ink cartridge and issue still present. Please call your printer manufacturer so that they can give you more options aside from sending it to service center. Thank you so much,
Tirzo
Jun 24, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
879 people viewed this question
Seeker5211
Seeker5211
