Question about Gateway 7320GZ Notebook
Another question how do I check the Bios to see what it is set on?
  • 114 Answers
It depends on the board. The second you turn on the PC Repeatedly press "DEL" if that doesn't try These:
ESC
F1
F2
F10
F12
Then you should be in the BIOS. Look for something related to a Hardware monitor, or Power Options. and when found, enter, and look for "Shutdown for CPU thermal" Either turn that off or raise it to 80C. and that should fix the computer. if it still shuts off 10 min later, it's a hardware issue where you should take it to your local Computer Shop.
Posted on Jun 11, 2008
Acer aspire 5315 slow. Has windows 10. Boot up says Media test failure
This generally indicates a bad HDD...but enter the bios and make sure first boot device is NOT set to Network in the bios or maybe the hdd has gone and its looking for a operating system to load....
Check cable connections (reseat),
Check jumpers on hard drive for Master/Slave or CS settings,
Check BIOS settings for boot order,
And lastly have your BIOS rescan your HD or
Reset your BIOS to defaults.....
To enter the Bios (see your computer screen at power on, your manual, or manufacturer's web site) you probably have to press something like the DEL Key, or one of the F Keys at boot up time, but the actual Key varies from model to model. Many computers refer to this as "Entering Setup", Setup is just another term for the Bios.
Setting your Bios to any safe default settings may also fix this for you.
Feb 03, 2018 | Acer Computers & Internet
My asus X200CA wont boot windows 8 anymore just says checking media and goes into bios settings?
try to check your bios on SATA controler , is there set by IDE or AHCI ?
on mine its AHCI , maybe can help ...
Oct 16, 2014 | Computers & Internet
When I start my computer I get the message PXE E61 Media Test Failure:check cable. Please, help me.
Make sure first boot device is NOT set to network in the bios or maybe the hdd has gone and its looking for a operatin system to load Check cable connections (reseat),
And lastly have your BIOS rescan your HD or reset your BIOS to defaults.
Put 'Hard Drive C:' before 'Network' in the boot order
(If the hard drive does not appear in the boot order, that's why the PXE network boot agents start)
Note : Check that the hard drive is seen in the BIOS setup
Aug 18, 2011 | Computers & Internet
Wanr to remove f1 to con and del to setup while booting my pc ie, directly boot
This because settings in your BIOS still error during POST..You can just simply set the BIOS setting with setting like 'disable error' or anything else like that. But might be better to check what happened to your BIOS. For example if you dont have Floppy drives then set in BIOS having Floppy drives this will give an error during POST..
Also if you saving the BIOS setting but BIOS wont save. It usually caused by battery, you can just simply replace it.
Aug 07, 2011 | Intel Motherboard
Asus P4S533-MX Bios problem
The average life span of a cmos battery is about five years.
The Asus P4S533-MX mother board hit the market in 2002/2003. Suggest you pull the bios battery and check its current voltage. It should read 3 volts DC. Double check the bios jumper. The jumper should be across pins 1 and 2 (This is Normal default setting). Open you're manual to page 1-15 for more information about the bios jumper. (CLRTC1). When in the bios you should set the time and date to current date and time. Save and exit the bios. When you boot your system and the bios auto loads it's self automatically usually its due from a wrong setting within the bios or its not maintaining its voltage. Consider the price of a new battery. See the link provided;
http://www.google.com/products/catalog?hl=en&q=cmos+battery&cid=7067940192546936833&sa=title#p
If you need the manual or drivers try the link provided;
http://support.asus.com/download/download_item.aspx?model=P4S533-MX&product=1&type=All&SLanguage=en
Happy holidays!
Mike
Dec 31, 2009 | ASUS P4S533 Motherboard
Alwyas get to bios cpu freq and hang
try clearing the bios and replace the bios battery.
Check the processors correct frequency and set it in the bios and save settings this should fix the problem.
Also check if your cooling fan on the processor is tightly fixed onto the cpu and motherboard
Dec 01, 2009 | ASUS P4S333-VM Motherboard
Bios settings changed automatically
Have you tried to update the bios? One of the latest versions BIOS Update [DPP3510J.86A] 07/15/09. But verify to ensure that you download the correct bios for your board. There are a few options available. Also check the jumper pins for the bios on the motherboard normal or (default) setting is pins 1-2 jumped.
Nov 10, 2009 | Computers & Internet
P4S800D.ROM not found
check the the bios battery, it should be 3volt not less,and press dell to in the bios page setup set and set everything you need to do.and don't forget to save it,. good luck
May 10, 2009 | ASUS P4S800D Motherboard
CD drive
You can enter into the BIOS settings by pressing Del key when the system is booting up.
Restore it to default settings. It might work... Not sure Just check it.
Feb 02, 2009 | Dell (8N816) Motherboard
Bios check sum error
Your bios defaulted. The battery keeps: date, time, and bios settings. You need to get in your bios and change the settings to what they need to be. You can enter the bios by hitting DEL during boot.
Dec 18, 2008 | Computers & Internet
Gateway 7320GZ Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
