If the freezer side is working and the refrigerator is not, its either your evaporator fan motor in the freezer side isn't running, or a defrost system problem. Open the freezer door to listen for the fan, and at the same time look to see if you have a build of ice on the back freezer wall. If you do, there is no circulation from the freezer side to cool the ref. The defrost system consist of a defrost timer, defrost thermostat and defrost heaters. The heaters rarely go out, so if you have to change the timer change the defrost thermostat as well since its a cheap part anyway. timer part number is 2188159 and the thermostat part number is 2196155.(called a bi-metal thermostat.)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
