Error code com 0001
We have a minolta bizhub Di1811p its a combination copier/fax. We keep getting this error code on most incoming faxes. We do receive some faxes and are able to fax out. Any ideas?
    Master:
  • 788 Answers
Sounds to me like a communication error. Is this phone line shared with a DSL modem? If so ensure you have a working DSL filter on the fax line. You should also change the phone line cable going from the fax machine to the filter or wall jack. Also remove any extension telephone that may be plugged into the fax machine to test if it is causing the problem.
If there is no problem with your line then there might be a problem with the modem in your machine. If this is the case then Konica Minolta should be able to replace it for your or sell you a replacement.
Posted on Jun 11, 2008
  • Dean Joly
    Dean Joly Jun 11, 2008
    Actually the fax module in that printer is an FX-3 fax module, that is what would need to be replaced if you can verify that your phone line is not causing the problem.
  • Dean Joly
    The transmission results report should have more information about the error. Print it and see what it says.
    Here's a link to the manual for the FX-3 fax unit: http://kmbs.konicaminolta.us/productsatt...
    Genius:
  • 1,447 Answers
Hi-
Go to fax settings and try turning off the ECM, if its off then switch it on, chances are its a communication error on the line. Keep me posted for further errors.
Have a nice day!!
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
TROUBLE CODE C173
the error code given does not match any in the C452 diagnostics
if you meant CB173 then the error reports to the fax control pwb and page sizeing error. reseat the fax board/ reset the fax borad to factory and then reprogram to current location ( cleariing any possible programing mistakes previously) set the correct marketing area ( see service manual) it is very rare for a fax board to go down, the problem likely remains with its install/programming/firmware levels.
Jan 16, 2014 | Konica Minolta Bizhub C452 Color Copier...
Reset error m1 in minolta bizhub 1811
Utility button, then stop 00 stop01 then use arrows to get to 9. Clear data, then clear maintenance counter =M-1
Nov 10, 2012 | Minolta Bizhub Di1811p Copier
I have Minolta DI 470 copier , and when i print from my computer it displays " error printer 1808" , i can't found any solution till now. Can anyone help me to solve this issue.
An 18xx code that can't be reset is caused by a problem with the image processing board. Most likely it will have to be replaced.
I'd call for service on this one.
Mar 06, 2011 | Konica Minolta Minolta DI1811P Digital...
Bizhub 161f not always answering an incoming fax...2nd try works but not always? Using the avaya phone system.
Avaya is a DIGITAL phone system, all fax machines are ANALOG. You nes a regular phone line for your fax
Jan 08, 2010 | Minolta BIZHUB 161F Black and White Copier
HOW DOES ONE PRINT A TEST PAGE ON A DI1811P
Go to Printer & Faxes -> Right click on the printer -> choose Properties -> Click on the Print Test Page
Aug 14, 2009 | Minolta Bizhub Di1811p Copier
Konica Minolta bizhub Di1811p i get error code C0F32
Need to replace the developer and drum and run required F8 and clear counters prior to the developer and drum replacement
Dec 05, 2008 | Minolta Office Equipment & Supplies
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Dec 12, 2007 | Konica Minolta bizhub C250 All-In-One...
148 people viewed this question
jasbo
jasbo
