There are many reasons for a dehumidifier to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
The humidity switch (Hydrometer sensor) may be at fault or compressor or fan is not running.First You could go directly to the compressor and make sure it is or is not
getting power first. If the compressor has power then the compressor is
suspect (sometimes when 1 wont start it gets hot to the touch) In any case the fan(s) should run with it on and trying to dehumidify. Look at my tips and tricks for compressor check out if it has power and dosn't run..
2 KINDS of CONTROLS for your DEHUMIDIFY
If it has an electronic display the sensor will be a small probe close to the inlet of the air inlet circulation. Maybe its not in place.This type control is not something that can usually be checked without an ohm meter, thermometer, and Hydrometer or Psychometric measuring device to arrive at the wet-dry bulb temperatures thus determining the humidity and charts to determine the resistance value of the sensor(s). So replace the board and sensor on this type.
dosn't run..
There
are many reasons why a dehumidifier will not work or collect water.
Here
Dehumidifier
heatman101
