Question about Maytag Neptune MAH5500B Front Load Washer
Cleaned out pump & still no fix....
I cleaned out the pump as well as the drain hose & the same problem is still happening. I ran the service mode & came up with a code of "23". This is the lock on the door, could the door lock be causing all the problem with the drain/spin cycle at the end of the wash cycle? Please help...
  • Anonymous Mar 30, 2014
    drain/pump fixed, but will not wash.
  • 868 Answers
YES !! Make sure your door lock light comes on when you are entering spin cycle.If it fails to come on your CONTROL BOARD is BAD, sorry!!
Posted on Jun 12, 2008
  • Archie Ferrarini
    Archie Ferrarini Jun 19, 2008
    Your door lock latch assembly has a small chance of being the cause here,but ,through 100's of these repairs Ive made the issue is in the Control board.
Water leaking through air vent and estimated time remaining sticks during the rinse cycle
Run a tub clean cycle. No clothes. No soap. Just vinegar. About a cup.
May 03, 2017 | LG Washing Machines
F & S GWL15 would not drain. Replaced pump & it drained for a while. Removed diverter, found a dime & some lint, cleaned it out and installed it. Still would not drain, water is on floor, do not see leak....
Have you tried reverse flushing the drain hose?
If you can get the outlet/drain hose to the washtub cold tap
wrap a towel around the hose and tap to stop water going everywhere whilst slowly turning up the water pressure
from the tap.
(Any leaks STOP and check your hose clamps/connections are all tight.)
Water should now be flowing into the machine bowl, and
hopefully turned the pump, and cleared any blockages.
Hope it helps
Sep 15, 2013 | Fisher Paykel EcoSmart GWL15
I have a hot point washin mashine that does not finish a wash and stopes half way through then lights at front of mashine start flashin
Had this with mine. Cleaned the filter (as decribed elsewhere on this site). Also cleaned the component fto which the drain hose attaches - guess this is the pump. Just unclip the drain hose and the hose going into this pump, and check there is nothing obstructing the pump. The clips are a bit of a fiddle, you might want 2 jubilee clips to replace them. Then ran a "maintenance wash" as per manual (ie a hot wash, no clothes, no detergent). Seems OK now
Nov 02, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Drain pump keeps running
Probable motor control board problem.
don't buy a GE anything!
May 03, 2010 | GE WBVH6240F Front Load Washer
My washer won't drain! The OE message was on, I
have you cleaned out the water pump and hose ? check drain hose for blockage, check pump wiring to make sure it has a good connection.120 volts to pump. pump or board bad.
Feb 01, 2010 | LG WM-2277HW Front Load Washer
Dishwasher does not drain and I have cycled it a couple of times to make sure. No line plugged and I've cleaned the filter.
After determining the pump was working in the unit I checked for a posible drain problem. I disconected the unit's drain hose from the drain vent in the sink and stuck it in a pan and then ran the unit again. It drained just fine. I then removed the drain vent at the sink and found it to be plugged. I cleaned it and all is working again.
Oct 03, 2009 | Bosch Integra® 800 SHX57C0xUC Built-in...
Failure to drain, stuck in the drain part of cycle
Try to drain as much water as possibel then remove front cover you will see the pump motor.unscrew the pump housing and look for some object that is blocking the impeller.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I cleaned the ac drain with bleach then ran the hose,
If there is no clogging, check the tilt angle of the pan. It should be leaning towards the drain.
May 08, 2009 | Heating & Cooling
Doesn't drain
is the pump kicking in? if so check the drain hose and the height on htat hose. If the pump does not kick on then it is the pump or an obstruction through the drain.
Feb 03, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
