Question about Gateway 7320GZ Notebook
Laptop shutting off
I have a gateway laptop and it keeps shutting off after approximately 10 minutes. I have it plugged in so it is not the battery shutting down. Could this be explained if the memory is low?
  • gixya Dec 10, 2008
    my gateway 7320 gz keeps shutting off as well. Of course it out of warranty so i am out of luck. Any help is appreciated!
  • 114 Answers
There might be a setting in the BIOS that shuts down the computer when the processor gets too hot. so, getting better cooling or turning off the setting will stop it. but, if you disable the setting, the Processor could overheat and explode.
Posted on Jun 11, 2008
My Acer 1681WLMi stopped recognising my battery after Windows 7 32bit was loaded. No battery detected) The computer works fine on Win7 with the AC power adapter plugged. But within 2-3 minutes of...
Please switch off the laptop and remove the battery. wait for 10 minutes and clean the battery and keep it in laptop. Connect the laptop to AC power.
Try to check whether the battery is detected in the BIOS setup.
If the BIOS is not detected then please exchange with the new battery from vender.
Jun 06, 2011 | Acer Aspire 1681WLMi Notebook
Battery was low, plugged it in and now it will not turn on...gateway lT27
Give it time to charge and try again. There are power setting that may be shutting down the machine at less than 10 or 5 % charge.....
Mar 16, 2011 | Gateway LT2001u Netbook
My new laptop keeps losing connection with my ZyXEL P-660HW-T1 V3 router. My old lap top worked fine, what could be the cuase?
The new laptops are not compatible with some of the older model routers.Try turning the power to the router for approximately 10 minutes,shut down your laptop before turning off the power to the router.once the router has been off for ten minutes,turn your laptop back on,as if you are "logging on",let your laptop be idle for about 20 minutes,giving your router time to "reboot" If this does not fix your problem,you'll have to replace your router with one that is more compatible....
Feb 12, 2011 | Zyxel P660HW-D1 Router
My battery light notifies my the battery is low so I plug in to the AC power and it still shuts off.
How long between plugging in and shut down? Many times what happens is it has already initiated the shut down sequence before you plug it in.
To prevent this, keep an eye on the power meter (put it in the systray if not already there) and proactively plug in the AC before it warns you. e.g. if it warns you at 10% when you see it reach 15% plug it in.
Mar 24, 2010 | Gateway 3520GZ PC Notebook
My Gateway 7510GX shuts down after ten minutes. I
i think there are two causes for this reason.1/ ur processer fan is not working properly. at that time u should get this message as thearmal heat. then ur computer shutdown. 2/ setting of power option my be fixed 10 minnutes. we should kee poweroption always never shutdown.
Jun 11, 2009 | Gateway 7510GX Notebook
Laptop shutting off
go to control panel and click on to power options. in that you can check whether you have accidentally set the notebook to shutdown after 10 min. thanks for contacting fixya!.
May 31, 2009 | Gateway 7320GZ Notebook
What do you think is wrong with my laptop?
Did you keep your laptop with you the entire time? Remove battery and plug in the power and see if it will come on.. If that doesn't work remove the battery for 15-20 minutes and then see put it back in plug it up and see if it works this time. If not the Airport might have been too rough with your baby...
Dec 23, 2008 | Gateway MT3705 Notebook
Gateway laptop
Probly its overheating and shuting down.But if it do turn on try to run in safe mode by pressing f8 when booting up.
May 28, 2008 | Computers & Internet
Gateway 3550 Internet shuts off every 10 minutes
I have a gateway laptop with Vista that does the same thing.
In the control panel/power settings, ID what power scheme you are using.
I found that when on power saver mode the wireless and CPU were throttled down to conserve power. In Vista you can adjust these up to max power while keeping the other features on the default power saver settings. It improved the dropped connections dramitically. To end the finger pointing I signed up for connection monitoring using DSL reports (DSLreports.com) This service sends a ping to your modem every 10 minutes and charts your ISP uptime. Using this service I was able to determine that it was not my ISP.
Good luck.
Nov 07, 2007 | Gateway 3550GZ Notebook
Gateway 7320GZ Notebook Logo
196 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
