Question about Technics SA-DX1040 Receiver
Sa-dx1040 dvd optical input works, tv and cd do not.
L connected a roku netflix player optical output to the cd optical input on the dx1040 and got no sound. I had the hdmi output directly connected to the tv set and thought that maybe that shut down the Roku's optical output. I talked to a Roku technician and he had me unplug the hdmi from the Roku to see if that worked. It had no effect. When I plugged the optical output from the Roku into the dvd input on the 1040 it worked great whether the hdmi was plugged in or not. Yes, I did change the input selection on the 1040. I also tried plugging into the 1040's tv optical input and that did not work either. Since I am using the dvd input for my dvd, I would really like to use one of the other 1040 optical inputs. Please help.
You have to manually select digital input on the receiver.
Posted on Aug 30, 2008
I have a Technics Stereo Receiver SA-EX320 and want to connect it to a Behringer Ultragraph Pro FBQ1502HD Equalizer. How can I do this?
Looking at the rear panel of the SA, the only way you can use the EQ is to hook the tape rec out to the EQ inputs, then the EQ outputs to the tape inputs. Then select tape monitor at the SA and your EQ will be working for you.
Jun 18, 2017 | Behringer Audio Players & Recorders
Conrad johnson converter connection
Hi sherring, have you cheked that your cable isnt damaged? the connecton at either end might be loose.
Dec 31, 2007 | Technics SA-AX530 Receiver
Have Technics SA-EX500 connected to Samsung Smart TV. For tv channels the sound is perfect but when I switch to Netflix or HBOGO the sound is static/cackling.
Suggest connecting via the headphones jack or if available the RCA audio output jacks. If you connect via the headphone jack you will need to adjust the TV volume to a lower setting to avoid distortion/./ The The problem is that the optical output connection is a digital connection and depending on the digital format the Digital to Analog converter may not be a configuration that the audio stream to the stereo required for the tv/vcr in.
How does the audio sound using the Samsung Smart TV internal speakers>
Also under menus/audio/settings you may need to change the Optical output to stereo.
Netflix also has settings that will change the audio stream.
Hope This helps?
Nov 21, 2016 | Samsung Audio Players & Recorders
Sound issue through Home theatre when pulling up applications
Smart TV's make up the audio output for your smart tv apps. You will need to use the Optical output of the TV and plug it into an available Optical input to the home theater receiver. Make note of the name of the input on the home theater receiver (i.e. CD/DVD, TV, DVD, etc) because that is the input you'll have to select on the receiver to hear the App audio. Hope that helps
Dec 03, 2014 | home Audio Players & Recorders
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Audio Players & Recorders
I am a woman, an elderly one at that. i am trying
Don't worry I will help you.
First
You must on your Roku player & Your laptop.
Play netflix again then its says enter code .
Follow these steps
1. Sign in to your netflix account on your pc then you see right hand on the top of side my account & help click there.
Scroll down & you got these options on the page.
WATCHING INSTANTLY ON YOUR TV OR COMPUTER
* Activate a Netflix ready device
then click here you get code. You should paste this code to your roku netflix.
Jun 07, 2010 | Technics SA-DX1040 Receiver
Adding another device to the system
Well, if analog works for you connect the CD player's analog RCA cables to the VCR inputs.
Can you imagine why you NEED to have the TV audio coming into the receiver from the TV? Are the TV's audio system or speakers superior to the audio section of every other source of TV-related programming? We hope not. Does the TV receive any programming that the receiver can not? Maybe games. I imagaine this MIGHT justify running analog TV audio back to the receiver.
Your cable box and your DVD player have both digital and analog audio outputs. The gray area is what your TV has for audio inputs. It could survive with simple RCA analog audio in from both and none to or from the receiver. Then you could watch Lo-Fi cable and DVD's without the receiver turned on.
That would free up the TV analog audio input for other things.
I imagine your DVD player is using one of the digital inputs on the receiver. If you have one each optical and coaxial audio output among your DVD and Cable Box you could place them in the two available diigital inputs.
Now, what about the CD's digital output? For stereo music you're not likely to be able to hear any difference between it and the analog input BUT it can still be connected digitally IF it has a coaxial output. Coaxial digital inputs can be shared.
Get an RCA-splitter and join the two units entering the coaxial audio input just before they enter that connection. Either will work just fine if you TURN THE OTHER ONE OFF when you want to us it.
Mar 19, 2010 | RCA RT2760 System
How to connect Netflix Roku player with pc and tv
Yes, it connects directly to your TV with a choice of cables - check their site for a description of your options there.  And if you have a wireless network (router) it will connect to the internet through that, so you don't need to have a cable running back to where your computer is.
Dec 25, 2008 | Technics SA-DX1040 Receiver
I am trying to set up a SA-TX50 A/V receiver, SH-300 processor, DVD player to my Philips LCD. I also have a digital cable box, seeking assistance. Mike
1. cable box video out to video 1 in on the lcd , audio out to reciever input 1 ( tv, vcr , or what you want it on )
2. dvd s-video output to lcd video 2 s-video input , dvd audio out to reciever dvd/cd audio input , and add the optical or coax cable digital audio for dolby digital surround sound
electech
Nov 26, 2008 | Technics SA-TX50 Receiver
Technics surround sound system
Use whatever TV sound output conforms to your receiver's input. If an optical or coaxial digital sound output is available, that is the way to get 5.1 surround sound through the SA-DX1050. But you have to assign the correct input (COAX, OPT1 or OPT2) to the selector (TV, DVD, CD). See pp 12-13 of the operationg instructions for D-Input instructions. If you don't have the manual you can download it at Panasonic.com.
Dec 29, 2007 | Technics SA-DX1050 Receiver
Technics SA-DX1040 Receiver Logo
1,120 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
