Question about GE DBXR463EBWW Electric Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
My GE dryer (don't know the actual model #) is about 3 years old, if that. We already replaced the heating element about 1 year ago. Now, dryer runs for about 3 - 5 minutes and then stops. Dryer is hot, so I know the heating element is working. The timer keeps running until the time is up even though the dryer itself stops running. HELP!!!! Is there an easy fix or should I just get a new dryer?
  • Anonymous Mar 24, 2014
    Possible bad timer? Works fine in regular press & timed heating.
  • Anonymous Mar 31, 2014
    TIMER COUNTS DOWN UNTIL LAST FEW MINUTES THEN WON'T CUT OFF.
    Genius:
  • 1,073 Answers
Remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Posted on Jun 11, 2008
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
GE Dryer DPSE810EG0WT, Possible element problem
If the heating element goes, Worst case scenario is a short and/or fire. More than likely it will just stop heating. Why run the risk?
Apr 26, 2012 | Dryers
Dryer heat won't come on every time. Sometimes
That is probably some burred contacts inside the timer. Most timers cannot be serviced but this timer can be if you are handy and careful. You can file down the contacts in this timer and it will work ok for a while and if it keeps on being intermittant you know you gotta buy a new timer. It is simpler and cheaper just to clean the contacts though.
Jan 20, 2010 | Dryers
GE Dryer works but keeps stopping after only 5 minutes
IT SOUNDS LIKE YOU NEED TO REPLACE TERMOSTATS.
Oct 19, 2009 | Dryers
Dries clothes but runs too long & clothes VERY hot
Fixable and possibly a warranty claim. The timer is bad. You will need to get behind the control panel and remove the timer and replace the timer. First I would call whoever it is that yall bought the dryer through and see how long your warranty is. Most of the warranties are only 1 year. But if you bought a extended warranty then you are covered. The part can be found at repairclinic.com
Feb 17, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer keeps running and timer continues to move around dial.
A common problem, had it happen to me.
Replace the timer control. takes about 15 minutes and the skill to remove screws, disconnect plug from old timer, remove timer, install new timer, connect plug, replace screws and panel, run dryer.
Reply the model number, and I'll get you the timer P/N.
Jan 15, 2009 | Kenmore 97572 Dryer
Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Oct 02, 2008 | Whirlpool LER4634J Electric Dryer
1-1/2 old dryer keeps stopping
could be a bad motor or timer contacts. can you hear a humming sound coming from the motor if you tried starting it again? if there is none, wait for about 5 mins and try starting it again, hear what happens?..
Feb 24, 2008 | GE DBXR463EBWW Electric Dryer
GE DBXR463EBWW Electric Dryer Logo
833 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
