I move this machine from one office to another office in the second floor.
Now I have the message Malfuntiion Call a techincial Code C0500
please help if,anyone had this problem before.
Thanks
Comments:
Aug 01, 2008
- The problem with Malfuntion call a technician code C0500 is a Fuser the fuser would need to be replace.
FUSER CODE. NOT SURE ON THIS SAME MODEL BUT ON OTHER DiALTA'S YOU NEED TO DO WHAT IS CALLED A "WARM RESET OR WARM REBOOT". tURN COPIER ON AND FIND A VER SMALL HOLE (PAPER CLIP SIZE) ON KEYBOARD OR SOME TIMES ON RIGHT HAND SIDE OF KEYBOARD, SOME TIMES SMALL SQUARE HOLE. STICK PAPER CLIP IN HOLE AND THAT WILL BRING YOU INTO SERVICE MODE. PANEL WILL SAY TROUBLE CODES, DEPRESS. TURN COPIER ON AND OFF AND SEE IF IT GETS YOU GOING. IF PROBLEM COMBES BACK YOU HAVE A BAD FUSER, EITHER FUSE, THERMISTER OR CONNECTORS.. GOOD LUCK
My MITA DC 1460 copier stops midway during the first part of the copy process and displays AF on the...
(More)
My MITA DC 1460 copier stops midway during the first part of the copy process and displays AF on the led display. What is causing this?
wont print, was printing with this display for awhile, then after a paper jam, stopped working. have...
(More)
wont print, was printing with this display for awhile, then after a paper jam, stopped working. have turned on /off
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
